[Nek5000-users] T-junction with two outlets
Mon Jul 7 12:27:52 CDT 2014
Hi Paul,
Thank you for the paper, very helpful. If you can find the routines that will be great, but in the meantime I’ll try to write the subroutines using the method discussed in the paper
Thanks again,
Ravon
On Jul 7, 2014, at 10:55 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Ravon,
> See the paper with Loth & Bassiouny on my webpage:
> www.mcs.anl.gov/~fischer/pubhtml/high_re.pdf
> I'll see if I can find the routines that allow you to control the flow split.
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Monday, July 07, 2014 9:37 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] T-junction with two outlets
> Hi Neks,
> I’m working on a simulation involving ducted flow of a t-jucntion with an inlet and two outlets.
> I want to be able to control the mass flow through one of the outlets.
> Has anyone every dealt with this issue, or are there any suggestion
> of how to write a subroutine to do this?
> Thanks,
> Ravon
> Nek5000-users mailing list
