[Nek5000-users] Pipe with expansion
Fri Jan 31 11:15:53 CST 2014
Hi Paul,
Thanks a lot for the reply. I am stuck with Set_obj() part of the
simulation could you please take a look at it.
Thank you,
Kamal
On 31/01/2014 18:17, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> For steady state, Nek supports only Stokes and conduction.
> There is some discussion of this on p. 16 of the manual, which
> you can find by following this link:
> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
> Best,
> Paul
> On Fri, 31 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I tried to simulated steady flow by setting the logical operator
>> IFTRAN = F but the simulation still runs in transient mode, How do I
>> get a steady time independent solution so that I can use it as my
>> Initial Condition ?
>> Thank you,
>> Kamal
>> On 29/01/2014 16:01, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello Paul,
>>> Thanks for the vorticity output and it worked.
>>> 1) I created a set-obj() for my pipe but how can I be sure that it
>>> has taken the full pipe wall surface in to account ?
>>>     I have attached the divpipe.usr file for your reference could
>>> 2) I even took torque_calc in to the .usr file and it gives out
>>> something like this
>>>      200  1.00000000000E+00 -9.76942759878E-06 -8.98721249598E-06
>>> -7.82215102801E-07      1torqx
>>>      200  1.00000000000E+00 -6.69169235606E-06 -6.35251009840E-06
>>> -3.39182257669E-07      1torqy
>>>      200  1.00000000000E+00  9.50518561890E-10 1.50349344990E-13
>>> 9.50368212545E-10       1torqz
>>> if I am not wrong are these the value of surface integral of viscous
>>> force in three components of velocity along three directions taken
>>> in the set_obj() ?
>>> because I would like to calculate this
>>> C_v =  F^v / ( d^2 * rho * U^2 ) =   double integral ( 1/Re * (du /
>>> dr) ) dtheta dz
>>> Thank you,
>>> Kamal.
>>> On 24/01/2014 13:02, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Kamal,
>>>> 1) yes
>>>> 2) standard approach to seeing vorticity would be something
>>>>    like the following in userchk
>>>>      parameter (lt=lx1*ly1*lz1*lelt)
>>>>      common /myjunk/ vort(lt,3),w1(lt),w2(lt)
>>>>      logical ifxyt
>>>>      integer ivout  ! flag to turn geometry on/off for VisIt
>>>>      save    ivout
>>>>      data    ivout /0/
>>>>      if (mod(istep,iostep).eq.0) then
>>>>         call comp_vort3(vort,w1,w2,vx,vy,vz)
>>>>         ifxyt = ifxyo   ! put geometry into first vrt file
>>>>         ifxyo = .false.
>>>>         if (ivout.eq.0) ifxyo = .true.
>>>>         ivout = 1
>>>>         call outpost(vort(1,1),vort(1,2),vort(1,3),pr,t,'vrt')
>>>>         ifxyo = ifxyt   ! restore ifxyo flag to original state
>>>>      endif
>>>> If your session name is blah, this piece of code will put
>>>> vorticity into a sequence of files vrtblah0.f0000n
>>>> You can instead ignore the vrt prefix and the part about the
>>>> geometry with a simpler code
>>>>      endif
>>>> I usually go for this latter approach, but the choice is
>>>> totally up to you.
>>>> Paul
>>>> On Fri, 24 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hello Paul,
>>>>> Thanks for your reply. I am looking into the .usr file for
>>>>> defining the set_obj ().
>>>>> 1) Could you please tell me what is 'Enter the number of levels ?'
>>>>> in n2to3
>>>>> is it the number of elements in Z direction ?
>>>>> 2) As you said about storing the computed vorticity in velocity
>>>>> field to view in VisIT, I found the routine to compute the
>>>>> vorticity but I am stuck about adding it to the velocity filed to
>>>>> VisIT ? could you please tell me how it works or any example which
>>>>> stores vorticity to the .fld file as a separate variable.
>>>>> Thank you
>>>>> Kamal
>>>>> On 22/01/2014 16:53, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Axial viscous stress is given by torq_calc -- that's no problem
>>>>>> whatsoever. You get a number as a
>>>>>> function of time.
>>>>>> You can even get stresses on multiple subsets of the geometry
>>>>>> (e.g., if you had multiple branches
>>>>>> in the domain or multiple cylinders.   The drag, which is a
>>>>>> byproduct of the torque computation (which
>>>>>> you can ignore), is given in terms of the viscous and pressure
>>>>>> components separately and as the
>>>>>> sum of the two.
>>>>>> You can identify domain boundaries by checking the boundary
>>>>>> conditions. Here, I recommend
>>>>>> looking at the set_obj routines in several of the /example cases.
>>>>>> ________________________________________
>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>>>> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
>>>>>> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>>>> Sent: Wednesday, January 22, 2014 9:37 AM
>>>>>> To: nek5000-users at lists.mcs.anl.gov
>>>>>> Subject: Re: [Nek5000-users] Pipe with expansion
>>>>>> Hello Paul
>>>>>> I was thinking about taking the tangential velocity near to the
>>>>>> wall so that I can figure out my length of the recirculation region.
>>>>>> Is it possible for me to access the boundary elements of the mesh
>>>>>> ??? so that I can take the boundary element and then obtain the
>>>>>> velocity at that point so that I can figure out the length of my
>>>>>> or take the *.fld file and read it to plot the datas I need.
>>>>>> I also want to calculate the axial viscous force acting on the
>>>>>> entire pipe.
>>>>>> which is given by
>>>>>> / dr) ) dtheta dz
>>>>>> On Jan 22, 2014, at 4:07 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi Kamal,
>>>>>>> As I thought about it some more, if you're interested in the
>>>>>>> local wall shear stress
>>>>>>> magnitude I'm quite certain you can get this by plotting the
>>>>>>> magnitude of vorticity
>>>>>>> on the surface in question.   (Note that the sign of the WSS,
>>>>>>> which in fact is a tensor
>>>>>>> or a vector when restricted to a given surface, is lost in this
>>>>>>> process, but that might
>>>>>>> not be relevant for your needs.)   If that works, then you can
>>>>>>> readily compute the
>>>>>>> vorticity using one of the routines in nek and store the result
>>>>>>> in a velocity field, then
>>>>>>> view that field with VisIt.   Of course WSS will require
>>>>>>> multiplication by viscosity.
>>>>>>> hth,
>>>>>>> Paul
>>>>>>> Sent: Tuesday, January 21, 2014 10:33 AM
>>>>>>> Hi paul,
>>>>>>> can I make this to be drag or shear quantities to be return to
>>>>>>> the a
>>>>>>> separate file so that it will easy for me to plot.
>>>>>>> By the way it gives the integral quantity. Think for example I
>>>>>>> need to
>>>>>>> find the shear stress on the wall  from the inlet to outlet at a
>>>>>>> particular time = 2 . How can I do that ?
>>>>>>> Is there way to find the number of elements in x,y and z
>>>>>>> direction ?
>>>>>>> On 21/01/2014 17:32, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>> Hi Kamal,
>>>>>>>> Your integrated drag quantities should be written to the logfile
>>>>>>>> (stdout),
>>>>>>>> assuming you've set the arguments in the call to be .true.
>>>>>>>> Paul
>>>>>>>> On Tue, 21 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>> Hi Paul,
>>>>>>>>> I checked the set_obj subroutine and implemented one in my
>>>>>>>>> .USR file.
>>>>>>>>> The code seem to run without any errors but I don't find where
>>>>>>>>> these
>>>>>>>>> variables are getting stored.
>>>>>>>>> I use VisIT to visualize my output, even there was no change
>>>>>>>>> in it.
>>>>>>>>> do I have to define my own output file and write the variables
>>>>>>>>> out ?
>>>>>>>>> Thanks,
>>>>>>>>> Kamal.
>>>>>>>>> On 20/01/2014 21:52, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>> Hi Kamal,
>>>>>>>>>> You'll need to compute your own tke by manipulating the
>>>>>>>>>> velocity fields.
>>>>>>>>>> You can get running averages of the requisite quantities
>>>>>>>>>> via calls to "avg_all" which is found in navier5.f
>>>>>>>>>> You can compute shear stress on the wall simply by computing
>>>>>>>>>> the drag on the wall, which can be done via a call to
>>>>>>>>>> torque_calc(),
>>>>>>>>>> also found in navier5.f
>>>>>>>>>> If you cd to /examples and type:
>>>>>>>>>>       grep torq */*.usr
>>>>>>>>>> you'll find many examples of calls to torque_calc. You simply
>>>>>>>>>> need to prescribe the surfaces on which shear is to be
>>>>>>>>>> integrated.
>>>>>>>>>> I typically write a routine "set_obj" to identify such surfaces
>>>>>>>>>> on the first call to usrchk.
>>>>>>>>>>       grep set_obj */*.usr
>>>>>>>>>> will show similar examples.
>>>>>>>>>> I would recommend trying this for laminar Poiseiulle flow in
>>>>>>>>>> a very simple channel just to check that your calls are properly
>>>>>>>>>> set.
>>>>>>>>>> Best,
>>>>>>>>>> Paul
>>>>>>>>>> On Mon, 20 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>> Hi Paul,
>>>>>>>>>>> Thanks and that helped.
>>>>>>>>>>> Where can I find the variables like Turbulent KE , shear
>>>>>>>>>>> stress on
>>>>>>>>>>> the wall. ?
>>>>>>>>>>> Do i have to activate some parameters for calculating them ?
>>>>>>>>>>> If I had to plot them.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Kamal
>>>>>>>>>>> On Jan 20, 2014, at 5:41 AM, nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Kamal,
>>>>>>>>>>>> Looks good.
>>>>>>>>>>>> I'm guessing that one further refinement would be:
>>>>>>>>>>>> if (z.gt.z0) scale = 1 + (smax-1)*(z-z0)/(z1-z0)
>>>>>>>>>>>> if (z.gt.z1) scale = smax
>>>>>>>>>>>> which would yield
>>>>>>>>>>>>   scale = 1 when z=z0
>>>>>>>>>>>>   scale = smax when z >= z1
>>>>>>>>>>>> Paul
>>>>>>>>>>>> On Sun, 19 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>>>>> Hi paul,
>>>>>>>>>>>>> The code works fine, but there should be a small change
>>>>>>>>>>>>> thats has
>>>>>>>>>>>>> to be done
>>>>>>>>>>>>> if (z.gt.z0) scale = 1 + (z /(z1-z0 )))
>>>>>>>>>>>>> This creates a perfect diverging pipe.
>>>>>>>>>>>>> Thanks for the help paul.
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>> On Jan 20, 2014, at 12:09 AM,
>>>>>>>>>>>>>> Hi paul,
>>>>>>>>>>>>>> If I am not wrong,
>>>>>>>>>>>>>> I make a mesh with three straight pipes( inlet, divergent,
>>>>>>>>>>>>>> outlet ) connected together via n2to3 so that I know the
>>>>>>>>>>>>>> element
>>>>>>>>>>>>>> connectivity places of the divergent section (z0,z1) and
>>>>>>>>>>>>>> use the
>>>>>>>>>>>>>> section what you gave
>>>>>>>>>>>>>> Thank you for the code
>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>> On Jan 19, 2014, at 8:45 PM,
>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>> I would do the following in usrdat2():
>>>>>>>>>>>>>>>    n=nx1*ny1*nz1*nelt
>>>>>>>>>>>>>>>    do i=1,n
>>>>>>>>>>>>>>>       x=xm1(i,1,1,1)
>>>>>>>>>>>>>>>       y=ym1(i,1,1,1)
>>>>>>>>>>>>>>>       z=ym1(i,1,1,1)
>>>>>>>>>>>>>>>       scale = 1.
>>>>>>>>>>>>>>>       if (z.gt.z0) scale = smax*(z-z0/(z1-z0)
>>>>>>>>>>>>>>>       xm1(i,1,1,1) = scale*x
>>>>>>>>>>>>>>>       ym1(i,1,1,1) = scale*y
>>>>>>>>>>>>>>>    enddo
>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>> Make certain that z1 and z0 correspond to z values
>>>>>>>>>>>>>>> that precisely coincide with element interfaces.
>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>> I looked into the Peris example but It is so what same
>>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>>> the stenosis example with a Cosine deformation.
>>>>>>>>>>>>>>>> In my case it is a pipe with conical divergent. I tried to
>>>>>>>>>>>>>>>> play around the variables Xm1, Ym1 and Zm1 but the mapping
>>>>>>>>>>>>>>>> doesn't go well.
>>>>>>>>>>>>>>>> Could you please help me with this.
>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>> On Jan 18, 2014, at 7:26 PM,
>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>> I looked at the Helix and stenosis example but they
>>>>>>>>>>>>>>>>> are using
>>>>>>>>>>>>>>>>> cosine functions to deform
>>>>>>>>>>>>>>>>> I tried to use a tangent function but it bends the
>>>>>>>>>>>>>>>>> whole pipe.
>>>>>>>>>>>>>>>>> I dint look at peris example .
>>>>>>>>>>>>>>>>> I will take a look at it and let you know.
>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>> On Jan 18, 2014, at 7:22 PM,
>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>> Have you looked at the peris example? The usr file there
>>>>>>>>>>>>>>>>>> shows how to deform
>>>>>>>>>>>>>>>>>> a pipe geometry.
>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>> Sent: Saturday, January 18, 2014 12:17 PM
>>>>>>>>>>>>>>>>>> Dear Paul,
>>>>>>>>>>>>>>>>>> I tried many ways to map my straight pipe geometry
>>>>>>>>>>>>>>>>>> but it
>>>>>>>>>>>>>>>>>> does not seem to work properly
>>>>>>>>>>>>>>>>>> I used something like
>>>>>>>>>>>>>>>>>> X = X + Z * tan ( alpha )
>>>>>>>>>>>>>>>>>> Y = Y + Z* tan (alpha )
>>>>>>>>>>>>>>>>>> even that dint work. could please help me with this
>>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>>> Kamal.
>>>>>>>>>>>>>>>>>> On Jan 17, 2014, at 2:24 PM,
>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>> Thanks paul. I tried working with the diverging mesh
>>>>>>>>>>>>>>>>>>> modification.
>>>>>>>>>>>>>>>>>>> I tried to use this form of equation to modify the mesh
>>>>>>>>>>>>>>>>>>> z = mx + b
>>>>>>>>>>>>>>>>>>> z = ny  + c
>>>>>>>>>>>>>>>>>>> x = ( z - b ) / m
>>>>>>>>>>>>>>>>>>> y = (z - c)  / n
>>>>>>>>>>>>>>>>>>> Do you think would work ? or is there any other way to
>>>>>>>>>>>>>>>>>>> input that ?
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>> On 17/01/2014 14:14,
>>>>>>>>>>>>>>>>>>> nek5000-users at lists.mcs.anl.govwrote:
>>>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>>>> 1) To check for convergence, run your simulation for
>>>>>>>>>>>>>>>>>>>> increasing polynomial orders ( lx1 in the SIZE
>>>>>>>>>>>>>>>>>>>> file) and
>>>>>>>>>>>>>>>>>>>> measure some consistent quantity (drag, TKE, etc). You
>>>>>>>>>>>>>>>>>>>> can plot this quantity against lx1 and this should
>>>>>>>>>>>>>>>>>>>> give
>>>>>>>>>>>>>>>>>>>> you a good picture of how you are converging (without
>>>>>>>>>>>>>>>>>>>> needing to change the physical mesh).
>>>>>>>>>>>>>>>>>>>> 2) If you weren't using temperature in your
>>>>>>>>>>>>>>>>>>>> simulation,
>>>>>>>>>>>>>>>>>>>> you could do put the following code snippet in your
>>>>>>>>>>>>>>>>>>>> userchk
>>>>>>>>>>>>>>>>>>>> c-------------------------------------------
>>>>>>>>>>>>>>>>>>>> integer i, ntot
>>>>>>>>>>>>>>>>>>>> ntot = nx1*ny1*nz1*nelv  ! total number of points in
>>>>>>>>>>>>>>>>>>>> simulation (on THIS processor)
>>>>>>>>>>>>>>>>>>>> do i = 1,ntot
>>>>>>>>>>>>>>>>>>>> t(i,1,1,1,1) = 0.5*(vx(i,1,1,1)**2 + vy(i,1,1,1)**2 +
>>>>>>>>>>>>>>>>>>>> vz(i,1,1,1)**2)
>>>>>>>>>>>>>>>>>>>> enddo
>>>>>>>>>>>>>>>>>>>> ifto = .true.
>>>>>>>>>>>>>>>>>>>> I've assumed here that your density is unity. This
>>>>>>>>>>>>>>>>>>>> computed kinetic energy point-wise and stores it in
>>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>>> temperature field. The part "ifto = .true." tells
>>>>>>>>>>>>>>>>>>>> Nek to
>>>>>>>>>>>>>>>>>>>> output the temperature field whenever it outputs a
>>>>>>>>>>>>>>>>>>>> field
>>>>>>>>>>>>>>>>>>>> file.  You could then view this in visit just like you
>>>>>>>>>>>>>>>>>>>> would the velocity field.
>>>>>>>>>>>>>>>>>>>> Hope this helps!
>>>>>>>>>>>>>>>>>>>> Josh
>>>>>>>>>>>>>>>>>>>> On Wed, Jan 15, 2014 at 9:52 AM,
>>>>>>>>>>>>>>>>>>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> I will try that mapping, I created a straight pipe
>>>>>>>>>>>>>>>>>>>> to do
>>>>>>>>>>>>>>>>>>>> some simulations.
>>>>>>>>>>>>>>>>>>>> 1) Is there a way to check my spectral convergence, so
>>>>>>>>>>>>>>>>>>>> that I can do some mesh convergence study?
>>>>>>>>>>>>>>>>>>>> 2) Is there a way to plot the kinetic energy in the
>>>>>>>>>>>>>>>>>>>> flow ?
>>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> On 15/01/2014 12:14,
>>>>>>>>>>>>>>>>>>>> Hi Kamal,
>>>>>>>>>>>>>>>>>>>> For the geometry you describe, I would apply mesh
>>>>>>>>>>>>>>>>>>>> morphing
>>>>>>>>>>>>>>>>>>>> to a standard straight pipe. You can create such a
>>>>>>>>>>>>>>>>>>>> pipe
>>>>>>>>>>>>>>>>>>>> using a subset of the mkmesh script provided in the
>>>>>>>>>>>>>>>>>>>> expansion
>>>>>>>>>>>>>>>>>>>> example.
>>>>>>>>>>>>>>>>>>>> If your transition region is conical, then I woud make
>>>>>>>>>>>>>>>>>>>> certain that the change in slope occurs at element
>>>>>>>>>>>>>>>>>>>> boundaries,
>>>>>>>>>>>>>>>>>>>> i.e., as in the half cross-section depicted below:
>>>>>>>>>>>>>>>>>>>> _______________
>>>>>>>>>>>>>>>>>>>>     ________________/  |   | |      |
>>>>>>>>>>>>>>>>>>>> +-----+-----+---+--+---+------+------+----> z
>>>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>>>> On Wed, 15 Jan 2014,
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> I looked at the example and it looks very helpful,
>>>>>>>>>>>>>>>>>>>> but for
>>>>>>>>>>>>>>>>>>>> a sudden expansion we have only two parts (i.e) the
>>>>>>>>>>>>>>>>>>>> inlet
>>>>>>>>>>>>>>>>>>>> pipe and the outlet pipe. Whereas in a diverging
>>>>>>>>>>>>>>>>>>>> pipe we
>>>>>>>>>>>>>>>>>>>> have three section (i.e,) The inlet pipe, Diverging
>>>>>>>>>>>>>>>>>>>> section and the outlet pipe.
>>>>>>>>>>>>>>>>>>>> Is it possible for me to create a 2D diverging section
>>>>>>>>>>>>>>>>>>>> using mesh modification and revolve it around the
>>>>>>>>>>>>>>>>>>>> centre
>>>>>>>>>>>>>>>>>>>> axis to get a 3d diverging pipe ?
>>>>>>>>>>>>>>>>>>>> or should I apply the mesh modification directly to
>>>>>>>>>>>>>>>>>>>> the 3d
>>>>>>>>>>>>>>>>>>>> sudden expansion pipe using usrdat2() ?
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> On 14/01/2014 21:09,
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> Thanks a lot for the update. I will take a look at
>>>>>>>>>>>>>>>>>>>> as soon
>>>>>>>>>>>>>>>>>>>> as possible and keep you updated with it.
>>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> On Jan 14, 2014, at 9:04 PM,
>>>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>>>> I've added an example for a step-type expansion in
>>>>>>>>>>>>>>>>>>>> a pipe.
>>>>>>>>>>>>>>>>>>>> New example directory
>>>>>>>>>>>>>>>>>>>> is nek5_svn/examples/expansion, with a README.
>>>>>>>>>>>>>>>>>>>> If you want a standard diffuser, I would use
>>>>>>>>>>>>>>>>>>>> mesh-morphing, as outlined in the
>>>>>>>>>>>>>>>>>>>> nek primer, which can be found on this page:
>>>>>>>>>>>>>>>>>>>> I've also automated our turbulent outflow bc
>>>>>>>>>>>>>>>>>>>> treatment --
>>>>>>>>>>>>>>>>>>>> one simply provides an
>>>>>>>>>>>>>>>>>>>> expansion factor (typically ~ 1.5) and two persistent
>>>>>>>>>>>>>>>>>>>> arrays to turb_outflow(), which
>>>>>>>>>>>>>>>>>>>> is now in navier5.f.    This can be useful when very
>>>>>>>>>>>>>>>>>>>> strong vortices are leaving the
>>>>>>>>>>>>>>>>>>>> domain, which is possible for certain diffuser flow
>>>>>>>>>>>>>>>>>>>> conditions (and others).
>>>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>>>> ofnek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>>>>>>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>>>>>>>>>>>>>>>>>> Subject: [Nek5000-users] Creating a Mesh
>>>>>>>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>>>>>>>> Can some one please help me in this because I am
>>>>>>>>>>>>>>>>>>>> new to nek
>>>>>>>>>>>>>>>>>>>> 1) How can I create a .rea for a specific geometry
>>>>>>>>>>>>>>>>>>>> say ' A
>>>>>>>>>>>>>>>>>>>> sudden
>>>>>>>>>>>>>>>>>>>> expansion pipe ' or a ' Diverging pipe '
>>>>>>>>>>>>>>>>>>>> 2) What tool I should use to create that mesh.
>>>>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>>>>> kamal
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>>>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>>>>>>>>>>>>>>> Josh Camp
>>>>>>>>>>>>>>>>>>>> "All that is necessary for the triumph of evil is that
>>>>>>>>>>>>>>>>>>>> good men do nothing" -- Edmund Burke
>>>>> Hello Paul,
>>>>> in n2to3
>>>>> Thank you
>>>>> Kamal
>>>>>> function of time.
>>>>>> sum of the two.
>>>>>> Hello Paul
>>>>>> entire pipe.
>>>>>> which is given by
>>>>>> / dr) ) dtheta dz
>>>>>>> Hi Kamal,
>>>>>>> readily compute the
>>>>>>> hth,
>>>>>>> Paul
>>>>>>> Hi paul,
>>>>>>> the a
>>>>>>> need to
>>>>>>> direction ?
>>>>>>>> Hi Kamal,
>>>>>>>> (stdout),
>>>>>>>> Paul
>>>>>>>>> Hi Paul,
>>>>>>>>> .USR file.
>>>>>>>>> these
>>>>>>>>> in it.
>>>>>>>>> out ?
>>>>>>>>> Thanks,
>>>>>>>>> Kamal.
>>>>>>>>>> Hi Kamal,
>>>>>>>>>> velocity fields.
>>>>>>>>>> torque_calc(),
>>>>>>>>>>       grep torq */*.usr
>>>>>>>>>> integrated.
>>>>>>>>>> set.
>>>>>>>>>> Best,
>>>>>>>>>> Paul
>>>>>>>>>>> Hi Paul,
>>>>>>>>>>> stress on
>>>>>>>>>>> the wall. ?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Kamal
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Kamal,
>>>>>>>>>>>> Looks good.
>>>>>>>>>>>> which would yield
>>>>>>>>>>>>   scale = 1 when z=z0
>>>>>>>>>>>> Paul
>>>>>>>>>>>>> Hi paul,
>>>>>>>>>>>>> thats has
>>>>>>>>>>>>> to be done
>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>> Hi paul,
>>>>>>>>>>>>>> If I am not wrong,
>>>>>>>>>>>>>> element
>>>>>>>>>>>>>> use the
>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>    n=nx1*ny1*nz1*nelt
>>>>>>>>>>>>>>>    do i=1,n
>>>>>>>>>>>>>>>       x=xm1(i,1,1,1)
>>>>>>>>>>>>>>>       y=ym1(i,1,1,1)
>>>>>>>>>>>>>>>       z=ym1(i,1,1,1)
>>>>>>>>>>>>>>>       scale = 1.
>>>>>>>>>>>>>>>    enddo
>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>>> doesn't go well.
>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>> are using
>>>>>>>>>>>>>>>>> whole pipe.
>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>> shows how to deform
>>>>>>>>>>>>>>>>>> a pipe geometry.
>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>> Dear Paul,
>>>>>>>>>>>>>>>>>> but it
>>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>>> Kamal.
>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>> modification.
>>>>>>>>>>>>>>>>>>> z = mx + b
>>>>>>>>>>>>>>>>>>> z = ny  + c
>>>>>>>>>>>>>>>>>>> x = ( z - b ) / m
>>>>>>>>>>>>>>>>>>> y = (z - c)  / n
>>>>>>>>>>>>>>>>>>> input that ?
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>>>> file) and
>>>>>>>>>>>>>>>>>>>> give
>>>>>>>>>>>>>>>>>>>> simulation,
>>>>>>>>>>>>>>>>>>>> userchk
>>>>>>>>>>>>>>>>>>>> integer i, ntot
>>>>>>>>>>>>>>>>>>>> do i = 1,ntot
>>>>>>>>>>>>>>>>>>>> vz(i,1,1,1)**2)
>>>>>>>>>>>>>>>>>>>> enddo
>>>>>>>>>>>>>>>>>>>> ifto = .true.
>>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>>> Nek to
>>>>>>>>>>>>>>>>>>>> field
>>>>>>>>>>>>>>>>>>>> Hope this helps!
>>>>>>>>>>>>>>>>>>>> Josh
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> to do
>>>>>>>>>>>>>>>>>>>> some simulations.
>>>>>>>>>>>>>>>>>>>> flow ?
>>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> Hi Kamal,
>>>>>>>>>>>>>>>>>>>> morphing
>>>>>>>>>>>>>>>>>>>> pipe
>>>>>>>>>>>>>>>>>>>> expansion
>>>>>>>>>>>>>>>>>>>> example.
>>>>>>>>>>>>>>>>>>>> boundaries,
>>>>>>>>>>>>>>>>>>>> _______________
>>>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> but for
>>>>>>>>>>>>>>>>>>>> inlet
>>>>>>>>>>>>>>>>>>>> pipe we
>>>>>>>>>>>>>>>>>>>> centre
>>>>>>>>>>>>>>>>>>>> the 3d
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> Hi Paul,
>>>>>>>>>>>>>>>>>>>> as soon
>>>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>>>> Kamal
>>>>>>>>>>>>>>>>>>>> Kamal,
>>>>>>>>>>>>>>>>>>>> a pipe.
>>>>>>>>>>>>>>>>>>>> treatment --
>>>>>>>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>>>>>>>> new to nek
>>>>>>>>>>>>>>>>>>>> say ' A
>>>>>>>>>>>>>>>>>>>> sudden
>>>>>>>>>>>>>>>>>>>> Thank you
>>>>>>>>>>>>>>>>>>>> kamal
>>>>>>>>>>>>>>>>>>>> Josh Camp
