[Nek5000-users] Projection of linearized equations onto reduced basis
Tue Jan 21 14:03:34 CST 2014
Hey Juan!
It turns out I had been working on a similar problem for the past few days
and came up with a small subroutine. It probably is not the most efficient
way to do it, but it at least work when I use global direct and adjoint
modes . I'll send it to you tomorrow, and if you wanna discuss, I can drop
by ONERA next week.
Cheers.
JC
2014/1/21 <nek5000-users at lists.mcs.anl.gov>
> Hi Neks,
> I would like to project the linearized NS equations onto a reduced basis
> formed by some POD modes (velocity vectors).
> We know that the perturbation equations can be read as du(t)/dx = A u(t),
> where
> // A = ( -U.grad(u) - u.grad(U) - grad(p) + 1/Re Lap(u)//
> To obtain the projected system, I need to compute the matrix Ar_i,j =
>  <U_i, AU_j> where U_j is the j mode (a vector containing the velocity
>  field).
> The step that  I  can't clearly see is the matrix-vector product A U_j.
>  Do  I  have to explicitily compute the matrix A  and then obtain the
> product? or is there a direct  way to  do  it  without this matrix (using
> the time-stepper)?
> Thanks in advance!
> Sincerely,
> Juan--
> Nek5000-users mailing list
Jean-Christophe Loiseau
Homepage <https://sites.google.com/site/loiseaujc/>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140121/876e55f6/attachment.html>
