[Nek5000-users] Pipe with expansion
Mon Jan 20 14:52:04 CST 2014
Hi Kamal,
You'll need to compute your own tke by manipulating the
velocity fields.
You can get running averages of the requisite quantities
via calls to "avg_all" which is found in navier5.f
You can compute shear stress on the wall simply by computing
the drag on the wall, which can be done via a call to torque_calc(),
also found in navier5.f
If you cd to /examples and type:
       grep torq */*.usr
you'll find many examples of calls to torque_calc.  You simply
need to prescribe the surfaces on which shear is to be integrated.
I typically write a routine "set_obj" to identify such surfaces
on the first call to usrchk.
       grep set_obj */*.usr
will show similar examples.
I would recommend trying this for laminar Poiseiulle flow in
a very simple channel just to check that your calls are properly
set.
Best,
Paul
On Mon, 20 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Thanks and that helped.
> Where can I find the variables like Turbulent KE , shear stress on the wall. ?
> Do i have to activate some parameters for calculating them ?
> If I had to plot them.
> Thanks,
> Kamal
> On Jan 20, 2014, at 5:41 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Kamal,
>> Looks good.
>> I'm guessing that one further refinement would be:
>> if (z.gt.z0) scale = 1 + (smax-1)*(z-z0)/(z1-z0)
>> if (z.gt.z1) scale = smax
>> which would yield
>>   scale = 1 when z=z0
>>   scale = smax when z >= z1
>> Paul
>> On Sun, 19 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi paul,
>>> The code works fine, but there should be a small change thats has to be done
>>> if (z.gt.z0) scale = 1 + (z /(z1-z0 )))
>>> This creates a perfect diverging pipe.
>>> Thanks for the help paul.
>>> Kamal
>>> On Jan 20, 2014, at 12:09 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi paul,
>>>> If I am not wrong,
>>>> I make a mesh with three straight pipes( inlet, divergent, outlet ) connected together via n2to3 so that I know the element connectivity places of the divergent section (z0,z1) and use the section what you gave
>>>> Thank you for the code
>>>> Kamal
>>>> On Jan 19, 2014, at 8:45 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Kamal,
>>>>> I would do the following in usrdat2():
>>>>>    n=nx1*ny1*nz1*nelt
>>>>>    do i=1,n
>>>>>       x=xm1(i,1,1,1)
>>>>>       y=ym1(i,1,1,1)
>>>>>       z=ym1(i,1,1,1)
>>>>>       scale = 1.
>>>>>       if (z.gt.z0) scale = smax*(z-z0/(z1-z0)
>>>>>       xm1(i,1,1,1) = scale*x
>>>>>       ym1(i,1,1,1) = scale*y
>>>>>    enddo
>>>>> Paul
>>>>> Make certain that z1 and z0 correspond to z values
>>>>> that precisely coincide with element interfaces.
>>>>>> Hi Paul,
>>>>>> I looked into the Peris example but It is so what same like the stenosis example with a Cosine deformation.
>>>>>> In my case it is a pipe with conical divergent. I tried to play around the variables Xm1, Ym1 and Zm1 but the mapping doesn't go well.
>>>>>> Could you please help me with this.
>>>>>> Thank you,
>>>>>> Kamal
>>>>>> On Jan 18, 2014, at 7:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi Paul,
>>>>>>> I looked at the Helix and stenosis example but they are using cosine functions to deform
>>>>>>> I tried to use a tangent function but it bends the whole pipe.
>>>>>>> I dint look at peris example .
>>>>>>> I will take a look at it and let you know.
>>>>>>> Thank you
>>>>>>> Kamal
>>>>>>> On Jan 18, 2014, at 7:22 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>> Kamal,
>>>>>>>> Have you looked at the peris example?  The usr file there shows how to deform
>>>>>>>> a pipe geometry.
>>>>>>>> Paul
>>>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>>>>>> Sent: Saturday, January 18, 2014 12:17 PM
>>>>>>>> To: nek5000-users at lists.mcs.anl.gov
>>>>>>>> Subject: Re: [Nek5000-users] Pipe with expansion
>>>>>>>> Dear Paul,
>>>>>>>> I tried many ways to map my straight pipe geometry but it does not seem to work properly
>>>>>>>> I used something like
>>>>>>>> X = X + Z * tan ( alpha )
>>>>>>>> Y = Y + Z* tan (alpha )
>>>>>>>> even that dint work. could please help me with this
>>>>>>>> Thank you
>>>>>>>> Kamal.
>>>>>>>> On Jan 17, 2014, at 2:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>> Hi Paul,
>>>>>>>>> Thanks paul. I tried working with the diverging mesh modification.
>>>>>>>>> I tried to use this form of equation to modify the mesh
>>>>>>>>> z = mx + b
>>>>>>>>> z = ny  + c
>>>>>>>>> x = ( z - b ) / m
>>>>>>>>> y = (z - c)  / n
>>>>>>>>> Do you think would work ? or is there any other way to input that ?
>>>>>>>>> Thanks,
>>>>>>>>> Kamal
>>>>>>>>> On 17/01/2014 14:14, nek5000-users at lists.mcs.anl.govwrote:
>>>>>>>>>> Kamal,
>>>>>>>>>> 1) To check for convergence, run your simulation for increasing polynomial orders ( lx1 in the SIZE file) and measure some consistent quantity (drag, TKE, etc).  You can plot this quantity against lx1 and this should give you a good picture of how you are converging (without needing to change the physical mesh).
>>>>>>>>>> 2) If you weren't using temperature in your simulation, you could do put the following code snippet in your userchk
>>>>>>>>>> c-------------------------------------------
>>>>>>>>>> integer i, ntot
>>>>>>>>>> ntot = nx1*ny1*nz1*nelv  ! total number of points in simulation (on THIS processor)
>>>>>>>>>> do i = 1,ntot
>>>>>>>>>> t(i,1,1,1,1) = 0.5*(vx(i,1,1,1)**2 + vy(i,1,1,1)**2 + vz(i,1,1,1)**2)
>>>>>>>>>> enddo
>>>>>>>>>> ifto = .true.
>>>>>>>>>> I've assumed here that your density is unity.  This computed kinetic energy point-wise and stores it in the temperature field.  The part "ifto = .true." tells Nek to output the temperature field whenever it outputs a field file.  You could then view this in visit just like you would the velocity field.
>>>>>>>>>> Hope this helps!
>>>>>>>>>> Josh
>>>>>>>>>> On Wed, Jan 15, 2014 at 9:52 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>>>>> Hi Paul,
>>>>>>>>>> I will try that mapping, I created a straight pipe to do some simulations.
>>>>>>>>>> 1) Is there a way to check my spectral convergence, so that I can do some mesh convergence study?
>>>>>>>>>> 2) Is there a way to plot the kinetic energy in the flow ?
>>>>>>>>>> Thank you,
>>>>>>>>>> Kamal
>>>>>>>>>> On 15/01/2014 12:14, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>> Hi Kamal,
>>>>>>>>>> For the geometry you describe, I would apply mesh morphing
>>>>>>>>>> to a standard straight pipe.  You can create such a pipe
>>>>>>>>>> using a subset of the mkmesh script provided in the expansion
>>>>>>>>>> example.
>>>>>>>>>> If your transition region is conical, then I woud make
>>>>>>>>>> certain that the change in slope occurs at element boundaries,
>>>>>>>>>> i.e., as in the half cross-section depicted below:
>>>>>>>>>>                            _______________
>>>>>>>>>>     ________________/  |   |      |      |
>>>>>>>>>>     +-----+-----+---+--+---+------+------+---->  z
>>>>>>>>>> Paul
>>>>>>>>>> On Wed, 15 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>> Hi Paul,
>>>>>>>>>> I looked at the example and it looks very helpful, but for a sudden expansion we have only two parts (i.e) the inlet pipe and the outlet pipe. Whereas in a diverging pipe we have three section (i.e,) The inlet pipe, Diverging section and the outlet pipe.
>>>>>>>>>> Is it possible for me to create a 2D diverging section using mesh modification and revolve it around the centre axis to get a 3d diverging pipe ?
>>>>>>>>>> or should I apply the mesh modification directly to the 3d sudden expansion pipe using usrdat2() ?
>>>>>>>>>> Thanks,
>>>>>>>>>> Kamal
>>>>>>>>>> On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>> Hi Paul,
>>>>>>>>>> Thanks a lot for the update. I will take a look at as soon as possible and keep you updated with it.
>>>>>>>>>> Thank you,
>>>>>>>>>> Kamal
>>>>>>>>>> On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>>> Kamal,
>>>>>>>>>> I've added an example for a step-type expansion in a pipe. New example directory
>>>>>>>>>> is nek5_svn/examples/expansion, with a README.
>>>>>>>>>> If you want a standard diffuser, I would use mesh-morphing, as outlined in the
>>>>>>>>>> nek primer, which can be found on this page:
>>>>>>>>>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>>>>>>>>>> I've also automated our turbulent outflow bc treatment -- one simply provides an
>>>>>>>>>> expansion factor (typically ~ 1.5) and two persistent arrays to turb_outflow(), which
>>>>>>>>>> is now in navier5.f.    This can be useful when very strong vortices are leaving the
>>>>>>>>>> domain, which is possible for certain diffuser flow conditions (and others).
>>>>>>>>>> Paul
>>>>>>>>>> ________________________________________
>>>>>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf ofnek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>>>>>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>>>>>>>> Subject: [Nek5000-users] Creating a Mesh
>>>>>>>>>> Hi
>>>>>>>>>> Can some one please help me in this because I am new to nek
>>>>>>>>>> 1) How can I create a .rea for a specific geometry say ' A sudden
>>>>>>>>>> expansion pipe ' or a ' Diverging pipe '
>>>>>>>>>> 2) What tool I should use to create that mesh.
>>>>>>>>>> Thank you
>>>>>>>>>> kamal
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>>>>> Josh Camp
>>>>>>>>>> "All that is necessary for the triumph of evil is that good men do nothing" -- Edmund Burke
