[Nek5000-users] Pipe with expansion
Sun Jan 19 13:45:05 CST 2014
Kamal,
I would do the following in usrdat2():
       n=nx1*ny1*nz1*nelt
       do i=1,n
          x=xm1(i,1,1,1)
          y=ym1(i,1,1,1)
          z=ym1(i,1,1,1)
          scale = 1.
          if (z.gt.z0) scale = smax*(z-z0/(z1-z0)
          if (z.gt.z1) scale = smax
          xm1(i,1,1,1) = scale*x
          ym1(i,1,1,1) = scale*y
       enddo
Paul
Make certain that z1 and z0 correspond to z values
that precisely coincide with element interfaces.
On Sun, 19 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> I looked into the Peris example but It is so what same like the stenosis example with a Cosine deformation.
> In my case it is a pipe with conical divergent. I tried to play around the variables Xm1, Ym1 and Zm1 but the mapping doesn't go well.
> Could you please help me with this.
> Thank you,
> Kamal
> On Jan 18, 2014, at 7:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> I looked at the Helix and stenosis example but they are using cosine functions to deform
>> I tried to use a tangent function but it bends the whole pipe.
>> I dint look at peris example .
>> I will take a look at it and let you know.
>> Thank you
>> Kamal
>> On Jan 18, 2014, at 7:22 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Kamal,
>>> Have you looked at the peris example?  The usr file there shows how to deform
>>> a pipe geometry.
>>> Paul
>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>> Sent: Saturday, January 18, 2014 12:17 PM
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: Re: [Nek5000-users] Pipe with expansion
>>> Dear Paul,
>>> I tried many ways to map my straight pipe geometry but it does not seem to work properly
>>> I used something like
>>> X = X + Z * tan ( alpha )
>>> Y = Y + Z* tan (alpha )
>>> even that dint work. could please help me with this
>>> Thank you
>>> Kamal.
>>> On Jan 17, 2014, at 2:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Paul,
>>>> Thanks paul. I tried working with the diverging mesh modification.
>>>> I tried to use this form of equation to modify the mesh
>>>> z = mx + b
>>>> z = ny  + c
>>>> x = ( z - b ) / m
>>>> y = (z - c)  / n
>>>> Do you think would work ? or is there any other way to input that ?
>>>> Thanks,
>>>> Kamal
>>>> On 17/01/2014 14:14, nek5000-users at lists.mcs.anl.govwrote:
>>>>> Kamal,
>>>>> 1) To check for convergence, run your simulation for increasing polynomial orders ( lx1 in the SIZE file) and measure some consistent quantity (drag, TKE, etc).  You can plot this quantity against lx1 and this should give you a good picture of how you are converging (without needing to change the physical mesh).
>>>>> 2) If you weren't using temperature in your simulation, you could do put the following code snippet in your userchk
>>>>> c-------------------------------------------
>>>>> integer i, ntot
>>>>> ntot = nx1*ny1*nz1*nelv  ! total number of points in simulation (on THIS processor)
>>>>> do i = 1,ntot
>>>>>    t(i,1,1,1,1) = 0.5*(vx(i,1,1,1)**2 + vy(i,1,1,1)**2 + vz(i,1,1,1)**2)
>>>>> enddo
>>>>> ifto = .true.
>>>>> I've assumed here that your density is unity.  This computed kinetic energy point-wise and stores it in the temperature field.  The part "ifto = .true." tells Nek to output the temperature field whenever it outputs a field file.  You could then view this in visit just like you would the velocity field.
>>>>> Hope this helps!
>>>>> Josh
>>>>> On Wed, Jan 15, 2014 at 9:52 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> Hi Paul,
>>>>> I will try that mapping, I created a straight pipe to do some simulations.
>>>>> 1) Is there a way to check my spectral convergence, so that I can do some mesh convergence study?
>>>>> 2) Is there a way to plot the kinetic energy in the flow ?
>>>>> Thank you,
>>>>> Kamal
>>>>> On 15/01/2014 12:14, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Kamal,
>>>>> For the geometry you describe, I would apply mesh morphing
>>>>> to a standard straight pipe.  You can create such a pipe
>>>>> using a subset of the mkmesh script provided in the expansion
>>>>> example.
>>>>> If your transition region is conical, then I woud make
>>>>> certain that the change in slope occurs at element boundaries,
>>>>> i.e., as in the half cross-section depicted below:
>>>>>                               _______________
>>>>>        ________________/  |   |      |      |
>>>>>        +-----+-----+---+--+---+------+------+---->  z
>>>>> Paul
>>>>> On Wed, 15 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Paul,
>>>>> I looked at the example and it looks very helpful, but for a sudden expansion we have only two parts (i.e) the inlet pipe and the outlet pipe. Whereas in a diverging pipe we have three section (i.e,) The inlet pipe, Diverging section and the outlet pipe.
>>>>> Is it possible for me to create a 2D diverging section using mesh modification and revolve it around the centre axis to get a 3d diverging pipe ?
>>>>> or should I apply the mesh modification directly to the 3d sudden expansion pipe using usrdat2() ?
>>>>> Thanks,
>>>>> Kamal
>>>>> On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Paul,
>>>>> Thanks a lot for the update. I will take a look at as soon as possible and keep you updated with it.
>>>>> Thank you,
>>>>> Kamal
>>>>> On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Kamal,
>>>>> I've added an example for a step-type expansion in a pipe. New example directory
>>>>> is nek5_svn/examples/expansion, with a README.
>>>>> If you want a standard diffuser, I would use mesh-morphing, as outlined in the
>>>>> nek primer, which can be found on this page:
>>>>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>>>>> I've also automated our turbulent outflow bc treatment -- one simply provides an
>>>>> expansion factor (typically ~ 1.5) and two persistent arrays to turb_outflow(), which
>>>>> is now in navier5.f.    This can be useful when very strong vortices are leaving the
>>>>> domain, which is possible for certain diffuser flow conditions (and others).
>>>>> Paul
>>>>> ________________________________________
>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf ofnek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>>>> Sent: Monday, January 13, 2014 3:35 AM
>>>>> Subject: [Nek5000-users] Creating a Mesh
>>>>> Hi
>>>>> Can some one please help me in this because I am new to nek
>>>>> 1) How can I create a .rea for a specific geometry say ' A sudden
>>>>> expansion pipe ' or a ' Diverging pipe '
>>>>> 2) What tool I should use to create that mesh.
>>>>> Thank you
>>>>> kamal
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>> Josh Camp
>>>>> "All that is necessary for the triumph of evil is that good men do nothing" -- Edmund Burke
