[Nek5000-users] Problem in 2d pipe simulation
Mon Jan 13 13:30:29 CST 2014
Hi Kamal,
Go to
https://nek5000.mcs.anl.gov/index.php/UG#Documentation
and click on the Nek5000 manual.  On pg. 35 there are
examples of how to specify functions.
Several of the cases in /examples also have prescribed functions
for boundary conditions --- for example, the Kovasznay case.
Best,
Paul
On Mon, 13 Jan 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks a lot.
> Could you please tell me where I can find more information of defining the .usr file.
> for example if I have boundary condition like this on a pipe
> " v,O,W,W  "
> and If I want to define a parabolic profile on the inlet say a value of 10 . How do I specific the edge ?
> Thank you.
> Kamal
> On Jan 13, 2014, at 7:58 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> When you create the .box file, it is important that the line containing the boundary conditions follows the format as described on the nek wiki and documentation.
>> It is a 3 character code that defines each boundary condition, and the whitespace must be maintained.  For example,
>> "v  ,A  ,W  ,W  ,   ,   "
>> would be a valid entry, whereas using less than 3 characters will result in commas and whitespace being entered into your .rea file.
>> More info and examples can be found:
>> http://nek5000.mcs.anl.gov/index.php/Genbox
>> Best,
>> Katie
>> On Mon, Jan 13, 2014 at 8:49 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> I created my .box file, with help of genbox I created .rea file.
>> later I created a .usr and SIZE file.
>> I have attached all the files I used with this mail
>> I launched the simulation and I got this error
>> |      _   __ ______ __ __  ______  ____    ____    ____   |
>> |     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
>> |    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
>> |   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
>> |  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
>> | NEK5000:  Open Source Spectral Element Solver            |
>> | COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
>> | Version:  1.0rc1 / SVN  r982                             |
>> | Web:      http://nek5000.mcs.anl.gov                     |
>>  Number of processors:           1
>>  REAL    wdsize      :           8
>>  INTEGER wdsize      :           4
>>   Beginning session:
>> /home/kamal/neksamples/mine/box.rea
>>  timer accuracy:   0.0000000E+00 sec
>>  read .rea file
>>  nelgt/nelgv/lelt:          15          15          15
>>  lx1  /lx2  /lx3 :           8           6           8
>>  mapping elements to processors
>>            0          15          15          15          15  NELV
>>  RANK     0 IEG       1       2       3       4       5 6       7       8
>>                       9      10      11      12      13      14 15
>>  element load imbalance:            0          15          15
>>  done :: mapping elements to processors
>>            0  objects found
>>  done :: read .rea file   0.67091E-03 sec
>>  Reset the target Courant number to .5
>>  setup mesh topology
>>    Right-handed check complete for      15 elements. OK.
>>    setvert2d:   8         252         792         252         252
>>  call usrsetvert
>>  done :: usrsetvert
>> gs_setup: 0 unique labels shared
>>    handle bytes (avg, min, max): 3972 3972 3972
>>    buffer bytes (avg, min, max): 0 0 0
>>    setupds time 1.9503E-04 seconds   0  8         252          15
>>            4  max multiplicity
>>  done :: setup mesh topology
>>  call usrdat
>>  done :: usrdat
>>  generate geometry data
>>  vol_t,vol_v:   1.9999999999999920        1.9999999999999920
>>  done :: generate geometry data
>>  call usrdat2
>>  done :: usrdat2
>>  regenerate geometry data           1
>>  vol_t,vol_v:   1.9999999999999938        1.9999999999999938
>>  done :: regenerate geometry data           1
>>  verify mesh topology
>>    0.0000000000000000        4.0000000000000000       Xrange
>>    0.0000000000000000       0.50000000000000000       Yrange
>>    0.0000000000000000        0.0000000000000000       Zrange
>>  done :: verify mesh topology
>>  103   Parameters from file:/home/kamal/neksamples/mine/box.rea
>>    1      1.00000         p1  DENSITY
>>    2     -20.0000         p2  VISCOS
>>    7      1.00000         p7  RHOCP
>>    8      1.00000         p8  CONDUCT
>>   11      1000.0          p11 NSTEPS
>>   12     -1.000000E-04    p12 DT
>>   15      100.000         p15 IOSTEP
>>   18      0.250000E-01    p18 GRID
>>   19     -1.00000         p19 INTYPE
>>   20      12.0000         p20 NORDER
>>   21      0.100000E-10    p21 DIVERGENCE
>>   22      0.100000E-11    p22 HELMHOLTZ
>>   24      0.100000E-09    p24 TOLREL
>>   25      0.100000E-09    p25 TOLABS
>>   26      1.00000         p26 COURANT/NTAU
>>   27      3.00000         p27 TORDER
>>   28      0.              p28 TORDER: mesh velocity (0: p28=p27)
>>   43      1.00000         p43 0=semg/1=schwarz
>>   66      4.00000         p66 output : <0=ascii, else binary
>>   67      4.00000         p67 restart: <0=ascii, else binary
>>   93      20.0000          p93 Number of previous pressure solns saved
>>   94      5.00000          p94 start projecting velocity after p94 step
>>   95      5.00000          p95 start projecting pressure after p95 step
>>   96      1.00000          p96 u0 translational velocity (in .usr)
>>   97      0.30000          p97 v0 translational velocity (in .usr)
>>   99      3.00000          p99   dealiasing: <0--> off/3--> old/4--> new
>>  102      1.00000          p102   Dump out divergence at each time step
>>  IFTRAN   = T
>>  IFFLOW   = T
>>  IFHEAT   = F
>>  IFSPLIT  = F
>>  IFLOMACH = F
>>  IFUSERVP = F
>>  IFUSERMV = F
>>  IFSTRS   = F
>>  IFCHAR   = F
>>  IFCYCLIC = F
>>  IFAXIS   = F
>>  IFMVBD   = F
>>  IFMELT   = F
>>  IFMODEL  = F
>>  IFKEPS   = F
>>  IFMOAB   = F
>>  IFNEKNEK = F
>>  IFSYNC   = T
>>  IFVCOR   = T
>>  IFINTQ   = F
>>  IFCWUZ   = F
>>  IFSWALL  = F
>>  IFGEOM   = F
>>  IFSURT   = F
>>  IFWCNO   = F
>>  IFTMSH for field           1    =  F
>>  IFADVC for field           1    =  T
>>  IFNONL for field           1    =  F
>>  Dealiasing enabled, lxd=          12
>>  Estimated eigenvalues
>>  EIGAA =    20.047633939712757
>>  EIGGA =    46987.971345031350
>>  EIGAE =   0.61685027506808487
>>  EIGAS =    3.8461538461538464E-003
>>  EIGGE =    46987.971345031350
>>  EIGGS =    2.0000000000000000
>>   E-solver strategy:  1 itr
>>            0          15  BC FAIL
>> EXIT: E INVALID BC FOUND in genfast         15
>> call exitt: dying ...
>> backtrace(): obtained 9 stack frames.
>> ./nek5000(print_stack_+0x1a) [0x4fe90a]
>> ./nek5000(exitt_+0x20f) [0x5bc0af]
>> ./nek5000(exitti_+0x12a) [0x5be72a]
>> ./nek5000(gen_fast_+0x581) [0x4fa701]
>> ./nek5000(set_overlap_+0x125) [0x4eb465]
>> ./nek5000(nek_init_+0x82d) [0x41affd]
>> ./nek5000(main+0x24) [0x419e54]
>> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fd9f1f33de5]
>> ./nek5000() [0x419e99]
>> total elapsed time             :   3.74889E-03 sec
>> total solver time incl. I/O    :   0.00000E+00 sec
>> time/timestep                  :   0.00000E+00 sec
>> CPU seconds/timestep/gridpt    :   0.00000E+00 sec
>> real    0m0.030s
>> user    0m0.020s
>> sys    0m0.000s
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
