[Nek5000-users] MPI problems
Fri Feb 28 18:01:46 CST 2014
Yes
you were right !
Changing mpiexec to mpiexec.mpich2 solved the problem !
Thanks a lot
Flavio
On 28/feb/2014, at 20:59, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I had a similar problem once. Changing mpiexec to mpiexec.mpich2 in the nekbmpi script solved it as far as I was concerned. Might be a similar problem?
> Cheers,
> JC
> 2014-02-28 17:15 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
> Dear Nek’s
> I have a problem when running the code on more than one processor.  The problem just appeared after a recent update of the system (debian) on our cluster. The code was working perfectly before the update but now I cannot run jobs in parallel anymore. MPI works with other softwares, but not with NEK. In particular I have the following problem:
> When I execute a parallel run using the script    nekmpi eddy_uv 4
> the command execute 4 different jobs running on a single processor rather than a single  job running on 4 processors. I attach the log to this mail (log.out) . After a few second three jobs are killed and only one remains active. A similar problem was also found on a new machine with a fresh installation of debian. It seems that the scripts is not able to set the correct value of the variable np (or_np).
> Anyone found a similar problem ? Any explanation for such behavior ? Any advice to solve the problem  ?
> Thanks in advance
> Flavio
> Platform
> uname -a
> Linux cfd 2.6.32-5-amd64 #1 SMP Mon Sep 23 22:14:43 UTC 2013 x86_64 GNU/Linux
> ompi_info
>                  Package: Open MPI manuel at ce170155 Distribution
>                 Open MPI: 1.4.2
>    Open MPI SVN revision: r23093
>    Open MPI release date: May 04, 2010
>                 Open RTE: 1.4.2
>    Open RTE SVN revision: r23093
>    Open RTE release date: May 04, 2010
>                     OPAL: 1.4.2
>        OPAL SVN revision: r23093
>        OPAL release date: May 04, 2010
>             Ident string: 1.4.2
>                   Prefix: /usr
>  Configured architecture: x86_64-pc-linux-gnu
>           Configure host: ce170155
>            Configured by: manuel
>            Configured on: Wed Sep  1 15:58:32 UTC 2010
>                 Built by: root
>                 Built on: Wed Sep  1 16:01:42 UTC 2010
>               Built host: ce170155
>               C bindings: yes
>             C++ bindings: yes
>       Fortran77 bindings: yes (all)
>       Fortran90 bindings: yes
>  Fortran90 bindings size: small
>               C compiler: gcc
>      C compiler absolute: /usr/lib/ccache/gcc
>             C++ compiler: g++
>    C++ compiler absolute: /usr/lib/ccache/g++
>       Fortran77 compiler: gfortran
>   Fortran77 compiler abs: /usr/bin/gfortran
>       Fortran90 compiler: gfortran
>   Fortran90 compiler abs: /usr/bin/gfortran
>              C profiling: yes
>            C++ profiling: yes
>      Fortran77 profiling: yes
>      Fortran90 profiling: yes
>           C++ exceptions: no
>           Thread support: posix (mpi: no, progress: no)
>            Sparse Groups: no
>   Internal debug support: no
>      MPI parameter check: runtime
> Memory profiling support: no
> Memory debugging support: no
>          libltdl support: yes
>    Heterogeneous support: yes
>  mpirun default --prefix: no
>          MPI I/O support: yes
>        MPI_WTIME support: gettimeofday
> Symbol visibility support: yes
>    FT Checkpoint support: yes  (checkpoint thread: no)
>            MCA backtrace: execinfo (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA memory: ptmalloc2 (MCA v2.0, API v2.0, Component v1.4.2)
>            MCA paffinity: linux (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA carto: auto_detect (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA carto: file (MCA v2.0, API v2.0, Component v1.4.2)
>            MCA maffinity: first_use (MCA v2.0, API v2.0, Component v1.4.2)
>            MCA maffinity: libnuma (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA timer: linux (MCA v2.0, API v2.0, Component v1.4.2)
>          MCA installdirs: env (MCA v2.0, API v2.0, Component v1.4.2)
>          MCA installdirs: config (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA crs: none (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA dpm: orte (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA pubsub: orte (MCA v2.0, API v2.0, Component v1.4.2)
>            MCA allocator: basic (MCA v2.0, API v2.0, Component v1.4.2)
>            MCA allocator: bucket (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: basic (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: hierarch (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: inter (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: self (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: sm (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: sync (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA coll: tuned (MCA v2.0, API v2.0, Component v1.4.2)
>                   MCA io: romio (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA mpool: fake (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA mpool: rdma (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA mpool: sm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA pml: cm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA pml: crcpw (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA pml: csum (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA pml: ob1 (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA pml: v (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA bml: r2 (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA rcache: vma (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA btl: ofud (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA btl: openib (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA btl: self (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA btl: sm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA btl: tcp (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA topo: unity (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA osc: pt2pt (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA osc: rdma (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA crcp: bkmrk (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA iof: hnp (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA iof: orted (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA iof: tool (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA oob: tcp (MCA v2.0, API v2.0, Component v1.4.2)
>                 MCA odls: default (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ras: slurm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ras: tm (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA rmaps: load_balance (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA rmaps: rank_file (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA rmaps: round_robin (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA rmaps: seq (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA rml: ftrm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA rml: oob (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA routed: binomial (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA routed: direct (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA routed: linear (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA plm: rsh (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA plm: slurm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA plm: tm (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA snapc: full (MCA v2.0, API v2.0, Component v1.4.2)
>                MCA filem: rsh (MCA v2.0, API v2.0, Component v1.4.2)
>               MCA errmgr: default (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ess: env (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ess: hnp (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ess: singleton (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ess: slurm (MCA v2.0, API v2.0, Component v1.4.2)
>                  MCA ess: tool (MCA v2.0, API v2.0, Component v1.4.2)
>              MCA grpcomm: bad (MCA v2.0, API v2.0, Component v1.4.2)
>              MCA grpcomm: basic (MCA v2.0, API v2.0, Component v1.4.2)
> Nek5000-users mailing list
> Jean-Christophe Loiseau
> Homepage
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140301/ee6968b0/attachment-0001.html>
