[Nek5000-users] auto_averager()
Fri Dec 5 15:06:20 CST 2014
Thanks Mohsen.... I'll take care of that.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, December 05, 2014 1:18 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] auto_averager()
Thanks Paul for your suggestion.
The failure occurs due to common block /scrns/ with array "ta" in
auto_averager. This block is also shared with the "restart" routine,
in which new values are apparently reassigned to it after each call.
It is solved by either defining a new block or moving "ta" to block /
scruz/.
Mohsen
On 4-Dec-14, at 10:31 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mohsen,
> I would suggest checking the range of the temperature inputs as
> they are read
> in auto_averager and then checking the range of the averages.
> Something like:
>       tmax = glmax(t,n)
>       tmin  = glmin(t,n)
>       if (nid.eq.0) write(6,*) k,tmin,tmax,' tmin'
> would produce those values...  then you can do something
> similar for the averaged result.
> Perhaps the failure occurs during the read process ... or.. etc.
> Paul
> Sent: Thursday, December 04, 2014 8:03 PM
> Subject: [Nek5000-users] auto_averager()
> Hello all,
> I am trying to take an average from previously averaged output
> "avgblah.f" files using the following calls in userchk in
> postprocessing
> mode:
> call auto_averager(filename)
> call outpost(vx,vy,vz,pr,t,'AVG')
> call exitti('exiting AVG routine$',icount)
> While I got the correct velocity field average, the average for the
> temperature field is not correct, as it is out of min/max range in the
> output files. I went through the "auto_averager" routine, but couldn't
> find anything wrong with that.
> So I was wondering if anyone has any thought on this issue that can
> help me.
> Thanks,
> Mohsen
> Nek5000-users mailing list
