[Nek5000-users] SFD error message from p66
Tue Aug 5 23:56:54 CDT 2014
Hello
I implemented an SFD for a 2d cylinder
https://bitbucket.org/cpraveen/nek5000/src/master/ext_cyl/
It seems to work but the residuals reduce by about 5 orders of magnitude
only. Maybe I am not choosing the parameters correctly. I would like to see
how others do it and compare with my own implementation.
Best
praveen
On Mon, Jun 30, 2014 at 1:21 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi SL
> We have implemented SFD some time ago and we can share the code if you
> wish. It is probably good to have single tested version of the code than
> develop number of variations. We've already shared the code with Elia.
> Regards
> Adam
> On 27/06/14 17:28, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Nek's,
>> I'm trying to program a Selective Frequency Damping following the article
>> of Akervik et. al (Physics of Fluids, 2006) and some Nek5000 posts.
>> I'm able to compile the code, however, when I try to run my simulation, I
>> find the following error message:
>>         0  0.0000E+00 Write checkpoint:
>>         0  0.0000E+00 OPEN:
>> At line 335 of file User/nek5_svn/trunk/nek/prepost.f (unit = 24, file =
>> Fortran runtime error: File '' does not exist
>> It seems to be something related to param 66. I've tried with p66=6, 0,
>> 1, -1, but I always get the same error.
>> Do you know what happens?
>> Thanks
>> SL
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140806/43b2a905/attachment.html>
