[Nek5000-users] Restart option failed
Fri Apr 11 10:43:17 CDT 2014
Is your restart file a 0.f00000 format?
If the param (67) is not set in the .usr file, the default is set to 0 .
f00000.
Katie
Katie
On Apr 11, 2014 9:56 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi Paul,
> I don't change parameters through the .usr file.
> Thank you
> Kamal
> On 11/04/2014 16:52, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Kamal,
> Make certain tey aren't reset in your .usr file.
> Best, Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Thursday, April 10, 2014 9:09 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Restart option failed
> Hi JC,
> Thanks for the reply
> The parameters are positive
>    0.00000     p064 =1 --> perturbation restart
>    1.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>    6.00000     p066 output : <0=ascii, else binary
>    6.00000     p067 restart: <0=ascii, else binary
> Regards,
> Kamal
> On 11/04/2014 14:18, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi Kamal,
> Check out the parameters 64 or 65 in your .rea file. It is very likely
> that it is set to -4 instead of a positive number.
>  Cheers,
> JC
> 2014-04-10 14:13 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
>> Hello Neks,
>> I tried to restart my simulation from a previous output *.f file but it
>> failed
>> I set the restart option in *.rea to 1 and added the file name.
>> Could some please tell me what might be the possible cause for this ?
>>  nekuic (1) for ifld            1
>>  Reading checkpoint data
>>        0       0 OPEN: extens0.f00250
>> extens0.f00250
>> byte_read() :: fopen failure2!
>> ERROR: Error reading restart header in mfi_prepare  ierr=  1
>> call exitt: dying ...
>> Thanks in advance.
>> Kamal
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Jean-Christophe Loiseau
> Homepage <https://sites.google.com/site/loiseaujc/>
> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140411/5f7582a4/attachment.html>
