[Nek5000-users] multiple runs and poisson for velocity
Fri Apr 4 13:01:37 CDT 2014
Hi Giuseppe,
If you look at the .usr file in examples/eddy_psi_omega/
you'll see a call for a Poisson solve for a little psi-omega formulation
of Navier-Stokes.
Please let me know if this provides the insight you seek for setting
up your Poisson solves.
Best regards,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, April 04, 2014 7:09 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] multiple runs and poisson for velocity
Dear Neks,
I have two issues that I would like to discuss with you.
Firstly, I would like to perform many steady state simulations with different values of the viscosity, each time using the previous solution as starting condition.
For this reason, I have built the following subroutine:
c-----------------------------------------------------------------------
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      do 120 ire=1,10
      param(2) = -1*ire
      call setprop
      igeom=1
      call fluid(igeom)
120 continue
      ifxyo = .true.
      call outpost(vx,vy,vz,pr,t,'ste')
      call exitt
      return
      end
but this does not work as I expected, could somebody suggest me what I should do instead?
Secondly, I would like to solve (in postprocessing mode) a Poisson problem for the velocity components, in the form -lapl(vx) = fx and -lapl(vy)=fy, with fx and fy known.
Is it possible to do this within NEK? I think this could be done by adapting the Uzawa pressure solver in navier1.f, but I am not sure if this could work.
Best regards,
Giuseppe
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
