[Nek5000-users] Running MOAB example
Thu Sep 12 13:43:25 CDT 2013
Hi All,
After fixing MOAB, I successully compiled MOAB example but when I tried
./nek pipe, it gave me this error
mv: cannot stat `pipe.log': No such file or directory
./nek5000: error while loading shared libraries: libhdf5.so.8: cannot open
shared object file: No such file or directory
real    0m0.001s
user    0m0.000s
sys    0m0.000s
can any one tell me what is the problem? FYI, I am using hdf5-1.8.11 with
zlib-1.2.5 and szip-2.1.
Ami
On Wed, Sep 11, 2013 at 1:30 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> On 09/11/2013 12:10 PM, Iulian Grindeanu wrote:
>>     Aha, good catch.
>>     Iulian, could you backport the imesh_freememory function?  Thanks.
>> Hello,
>> The Version 4.6 was released on February 11. The link to the tar ball is
>> in the web page.
>> http://trac.mcs.anl.gov/**projects/ITAPS/wiki/MOAB<http://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB>
>> http://ftp.mcs.anl.gov/pub/**fathom/moab-4.6.0.tar.gz<http://ftp.mcs.anl.gov/pub/fathom/moab-4.6.0.tar.gz>
>> (so this is the official release 4.6)
>> The current Version4.6 branch, in the git repository, already has the
>> free memory function backported.
>> That tarball is updated nightly, and you can get it from this link (on
>> the moab wiki page too)
>> http://ftp.mcs.anl.gov/pub/**fathom/moab-4.6-nightly.tar.gz<http://ftp.mcs.anl.gov/pub/fathom/moab-4.6-nightly.tar.gz>
>> Is this what they need?
> Ok, yes, that's what they need, thanks.
> - tim
>  Thanks,
>> Iulian
>>     - tim
>>     On 09/11/2013 11:33 AM, Vijay S. Mahadevan wrote:
>>      > The linker error is because of your version mismatch. You need to
>>      > update your moab to the latest version. I see you are using v4.6
>> now.
>>      > You should be able to use the dev version from
>>      > https://bitbucket.org/**fathomteam/moab<https://bitbucket.org/fathomteam/moab>with git or download the newer
>>      > patch from https://trac.mcs.anl.gov/**projects/ITAPS/wiki/MOAB<https://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB>
>>      > Tim, can we create a new patched version of the release for
>> download.
>>      > I spoke to Rajeev about this some time back but we need to decide
>> what
>>      > fixes to backport.
>>      > Vijay
>>      > On Wed, Sep 11, 2013 at 11:20 AM,  <nek5000-users at lists.mcs.anl.**
>> gov <nek5000-users at lists.mcs.anl.gov>> wrote:
>>      >> Yes , I am using gnu, and whwen I add USR_LFLAGS="-lmpi_cxx
>> -lstdc++,
>>      >> I get this,
>>      >> makenek - automatic build tool for Nek5000
>>      >> generating makefile ...
>>      >> mpif77 -c  -O2 -fdefault-real-8 -x f77-cpp-input -fcray-pointer
>> -DMOAB
>>      >> -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
>>      >> -I/home/amirreza/nek5_svn/**amirreza_test/examples/moab
>>      >> -I/home/amirreza/nek5_svn/**trunk/nek -I./
>>      >> /home/amirreza/nek5_svn/**amirreza_test/examples/moab/**pipe.f
>>      >> -I/home/amirreza/nek5_svn/**trunk/nek/3rd_party
>>      >> -I/home/amirreza/Amirreza/**moab-4.6.0/gcc/include  -o obj/pipe.o
>>      >> mpif77 -o nek5000  obj/pipe.o obj/drive.o obj/drive1.o
>> obj/drive2.o
>>      >> obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
>>      >> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
>>      >> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
>>      >> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
>>      >> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o
>> obj/math.o
>>      >> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
>>      >> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
>> obj/hsmg.o
>>      >> obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
>> obj/navier6.o
>>      >> obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o obj/calcz.o
>> obj/byte.o
>>      >> obj/chelpers.o obj/byte_mpi.o obj/postpro.o obj/cvode_driver.o
>>      >> obj/nek_comm.o obj/init_plugin.o obj/setprop.o obj/qthermal.o
>>      >> obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o obj/dsygv.o
>>      >> obj/nek_in_situ.o obj/mxm_std.o obj/blas.o obj/moab.o
>> obj/imeshutil.o
>>      >> obj/imeshcutil.o obj/comm_mpi.o obj/singlmesh.o obj/jl_gs.o
>> obj/jl_sort.o
>>      >> obj/jl_sarray_transfer.o obj/jl_sarray_sort.o obj/jl_gs_local.o
>>      >> obj/jl_crystal.o obj/jl_comm.o obj/jl_tensor.o obj/jl_fail.o
>>      >> obj/jl_fcrystal.o obj/jl_findpts.o obj/jl_findpts_local.o
>> obj/jl_obbox.o
>>      >> obj/jl_poly.o obj/jl_lob_bnd.o obj/jl_findpts_el_3.o
>> obj/jl_findpts_el_2.o
>>      >> obj/jl_sparse_cholesky.o obj/jl_xxt.o obj/jl_fcrs.o
>>      >> -L/home/amirreza/Amirreza/**netcdf-4.1.3/gcc/lib
>>      >> -L/home/amirreza/Amirreza/**zlib-1.2.5/gcc/lib
>>      >> -L/home/amirreza/Amirreza/**szip-2.1/gcc/lib
>>      >> -L/home/amirreza/Amirreza/**hdf5-1.8.11/lib
>>      >> -L/home/amirreza/Amirreza/**moab-4.6.0/gcc/lib
>>      >> -L/home/amirreza/Amirreza/**moab-4.6.0/gcc/lib -liMesh -lMOAB
>> -lnetcdf  -lhdf5
>>      >> -lsz   -lm  -lmpi_cxx -lstdc++
>>      >> obj/moab.o: In function `nekmoab_intbc_':
>>      >> moab.f:(.text+0xe9d): undefined reference to `imesh_freememory_'
>>      >> moab.f:(.text+0xece): undefined reference to `imesh_freememory_'
>>      >> moab.f:(.text+0xee4): undefined reference to `imesh_freememory_'
>>      >> moab.f:(.text+0xf05): undefined reference to `imesh_freememory_'
>>      >> obj/moab.o: In function `nekmoab_bc_':
>>      >> moab.f:(.text+0x1306): undefined reference to `imesh_freememory_'
>>      >> collect2: ld returned 1 exit status
>>      >> make: *** [nek5000] Error 1
>>      >> Thanks,
>>      >> Ami
>>      >> On Wed, Sep 11, 2013 at 12:05 PM, <nek5000-users at lists.mcs.anl.**
>>      >>> It depends which compiler you're using.  Are you using gnu?
>>      >>> Please send complete compile output.
>>      >>> - tim
>>      >>> On 09/11/2013 10:11 AM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>      >>>> Thanks for your answer, to make sure I have added libraries to
>> makenek
>>      >>>> ''USR_LFLAGS="-lmpi_cxx -lstdc++" which I'm
>>      >>>> getting same error,so you mean I need to add appropriate
>> fortran library
>>      >>>> to USR_LFLAGS?
>>      >>>> Thanks,
>>      >>>> Ami
>>      >>>> On Wed, Sep 11, 2013 at 10:47 AM, <nek5000-users at lists.mcs.anl.
>> **gov <nek5000-users at lists.mcs.anl.gov>
>>      >>>> <mailto:nek5000-users at lists.**mcs.anl.gov<nek5000-users at lists.mcs.anl.gov>>>
>> wrote:
>>      >>>>      Hi Ami,
>>      >>>>         That's the C++ runtime.  You have two options:
>>      >>>>      1. Link with the C++ compiler; in this case, you'll have to
>>      >>>> explicitly add the fortran runtime libraries to the link
>>      >>>>      statement, which is most easily done by adding it to
>> USR_LFLAGS in
>>      >>>> makenek.  Compiler documents often tell you which
>>      >>>>      libraries implement the fortran runtime, usually in a
>> section about
>>      >>>> inter-language linking.
>>      >>>>      2. Add the C++ std libs to USR_LFLAGS.  The
>> trunk/nek/makenek file
>>      >>>> has a few examples of this method for
>>      >>>>      gnu/intel/pgi.  Sometimes, like on BG/x, it can be
>> difficult to
>>      >>>> figure out what all comprises the C++ runtime, which
>>      >>>>      is why I list 1. above.
>>      >>>>      - tim
>>      >>>>      On 09/11/2013 09:31 AM, nek5000-users at lists.mcs.anl.__**
>> gov
>> wrote:
>>      >>>>          Hello Neks,
>>      >>>>          I am trying to run MOAB example with nek5000, but all
>> the time
>>      >>>> which I am running, it gives me set of undefined
>>      >>>>          reference error. I put an error with last part of my
>> ./makenek
>>      >>>> pipe log below.
>>      >>>>          What is wrong with my work?
>>      >>>>          IODebugTrack.cpp:(.text+0xb74)**__: undefined
>> reference to
>>      >>>> `std::basic_ostream<char, std::char_traits<char> >&
>>      >>>>          std::operator<< <std::char_traits<char>
>>      >>>>> (std::basic_ostream<char, std::char_traits<char> >&, char
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xb7f)**__: undefined
>> reference to
>>      >>>>            >::operator<<(unsigned long)'
>>      >>>>          IODebugTrack.cpp:(.text+0xb8c)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xb97)**__: undefined
>> reference to
>>      >>>>          IODebugTrack.cpp:(.text+0xbd3)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xbde)**__: undefined
>> reference to
>>      >>>>          IODebugTrack.cpp:(.text+0xbeb)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xbf6)**__: undefined
>> reference to
>>      >>>>          IODebugTrack.cpp:(.text+0xc03)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xc0e)**__: undefined
>> reference to
>>      >>>>          IODebugTrack.cpp:(.text+0xc1b)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xc26)**__: undefined
>> reference to
>>      >>>>          IODebugTrack.cpp:(.text+0xc33)**__: undefined
>> reference to
>> const*)'
>>      >>>>          IODebugTrack.cpp:(.text+0xc38)**__: undefined
>> reference to
>>      >>>>          std::endl<char, std::char_traits<char>
>>      >>>> std::char_traits<char> >&)'
>>      >>>>          IODebugTrack.cpp:(.text+0xc40)**__: undefined
>> reference to
>>      >>>>            >::operator<<(std::basic___**ostream<char,
>>      >>>>> & (*)(std::basic_ostream<char,
>>      >>>>          std::char_traits<char> >&))'
>>      >>>>          IODebugTrack.cpp:(.text+0xc50)**__: undefined
>> reference to
>>      >>>>           >::flush()'
>>      >>>> /home/amirreza/Amirreza/moab-_**_4.6.0/gcc/lib/libMOAB.a(__**IODebugTrack.o):
>> In
>>      >>>> function
>>      >>>>          `moab::IODebugTrack::all___**reduce()':
>>      >>>>          IODebugTrack.cpp:(.text+0xd08)**__: undefined
>> reference to
>>      >>>> `MPI_Comm_size'
>>      >>>>          IODebugTrack.cpp:(.text+0xdfe)**__: undefined
>> reference to
>>      >>>> `MPI_Gather'
>>      >>>>          IODebugTrack.cpp:(.text+__**0x1080): undefined
>> reference to
>>      >>>> `MPI_Gatherv'
>> In
>>      >>>> function
>>      >>>>          `__static_initialization_and__**_destruction_0(int,
>> int)':
>>      >>>>          IODebugTrack.cpp:(.text+__**0x1221): undefined
>> reference to
>>      >>>> `std::ios_base::Init::Init()'
>>      >>>>          IODebugTrack.cpp:(.text+__**0x1226): undefined
>> reference to
>>      >>>> `std::ios_base::Init::~Init()'
>> In
>>      >>>> function
>>      >>>>          `std::list<moab::IODebugTrack:**__:DRange,
>>      >>>>          std::allocator<moab::__**IODebugTrack::DRange>
>>      >>>>> ::_M_insert(std::_List___**iterator<moab::IODebugTrack::_**
>> _DRange>,
>>      >>>>          moab::IODebugTrack::DRange const&)':
>>     IODebugTrack.cpp:(.text.___**ZNSt4listIN4moab12IODebugTrack**
>> __6DRangeESaIS2_EE9_M___**insertESt14_List_iteratorIS2__**
>> _ERKS2_[std::list<moab::__**IODebugTrack::DRange,
>> _DRange>,
>>      >>>>          moab::IODebugTrack::DRange const&)]+0x3a): undefined
>> reference to
>>      >>>> `std::__detail::_List_node___**base::_M_hook(std::__detail::_**
>> __List_node_base*)'
>> In
>>      >>>> function
>>      >>>> `__gnu_cxx::new_allocator<std:**__:_List_node<moab::__**
>>      >>>>            >::deallocate(std::_List_node<**
>> __moab::IODebugTrack::DRange>***,
>>      >>>> unsigned long)':
>>     IODebugTrack.cpp:(.text._ZN9__**__gnu_cxx13new_allocatorISt10_**
>> __List___**nodeIN4moab12IODebugTrack6DRan**__geEEE10deallocateEPS5_m[__**
>> gnu___cxx::new_allocator<std::**_List___node<moab::**
>> IODebugTrack::__DRange>
>>      >>>> unsigned long)]+0x1c): undefined reference to
>>      >>>>          `operator
>>      >>>>          delete(void*)'
>> In
>>      >>>> function
>>      >>>> `__gnu_cxx::new_allocator<__**moab::IODebugTrack::DRange>::_**
>> _allocate(unsigned
>>      >>>> long, void const*)':
>>     IODebugTrack.cpp:(.text._ZN9__**__gnu_cxx13new___**
>> allocatorIN4moab12IODebugTrack**__6DRangeEE8allocateEmPKv[__**
>> gnu___cxx::new_allocator<moab:**:__IODebugTrack::DRange>::__**
>> allocate(unsigned
>>      >>>>          long, void const*)]+0x2c): undefined reference to
>>      >>>> `std::__throw_bad_alloc()'
>> allocate(unsigned
>>      >>>>          long, void const*)]+0x45): undefined reference to
>> `operator
>>      >>>> new(unsigned long)'
>> In
>>      >>>> function
>> _deallocate(moab::**IODebugTrack:__:DRange*,
>>      >>>> unsigned
>>      >>>>          long)':
>> allocatorIN4moab12IODebugTrack**__6DRangeEE10deallocateEPS3_m[**
>> ____gnu_cxx::new_allocator<**moab::__IODebugTrack::DRange>:**
>> :__deallocate(moab::**IODebugTrack:__:DRange*,
>>      >>>>          unsigned long)]+0x1c): undefined reference to `operator
>>      >>>> delete(void*)'
>> In
>>      >>>> function
>>      >>>>> ::allocate(unsigned long, void const*)':
>> __List___**nodeIN4moab12IODebugTrack6DRan**__geEEE8allocateEmPKv[__gnu_**
>> cxx:__:new_allocator<std::_**List___node<moab::**IODebugTrack::__DRange>
>>      >>>>            >::allocate(unsigned long, void const*)]+0x2c):
>> undefined
>>      >>>> reference to `std::__throw_bad_alloc()'
>>      >>>>            >::allocate(unsigned long, void const*)]+0x46):
>> undefined
>>      >>>> reference to `operator new(unsigned long)'
>> IODebugTrack.o):(.eh_frame+__**0x24b):
>>      >>>>          `__gxx_personality_v0'
>>      >>>> /home/amirreza/Amirreza/moab-_**_4.6.0/gcc/lib/libMOAB.a(__**OrientedBox.o):
>> In
>>      >>>> function
>>      >>>>          `moab::operator<<(std::basic__**_ostream<char,
>>      >>>> std::char_traits<char> >&, moab::OrientedBox const&)':
>>      >>>>          OrientedBox.cpp:(.text+0x97): undefined reference to
>>      >>>>          std::operator<<
>>      >>>>          <std::char_traits<char> >(std::basic_ostream<char,
>>      >>>> std::char_traits<char> >&, char const*)'
>>      >>>>          OrientedBox.cpp:(.text+0xaf): undefined reference to
>>      >>>>          std::operator<<
>>      >>>>          OrientedBox.cpp:(.text+0xbc): undefined reference to
>>      >>>>           >::operator<<(double)'
>>      >>>>          OrientedBox.cpp:(.text+0xc9): undefined reference to
>>      >>>>          std::operator<<
>>      >>>>          OrientedBox.cpp:(.text+0xe1): undefined reference to
>>      >>>>          std::operator<<
>>      >>>>          OrientedBox.cpp:(.text+0xee): undefined reference to
>>      >>>>          OrientedBox.cpp:(.text+0xfb): undefined reference to
>>      >>>>          std::operator<<
>>      >>>>          OrientedBox.cpp:(.text+0x113): undefined reference to
>> const*)'
>>      >>>>          OrientedBox.cpp:(.text+0x120): undefined reference to
>> In
>>      >>>> function
>> int)':
>>      >>>>          OrientedBox.cpp:(.text+0x3aaf)**__: undefined
>> reference to
>>      >>>>          OrientedBox.cpp:(.text+0x3ab4)**__: undefined
>> reference to
>> In
>>      >>>> function `moab::ErrorCode
>>      >>>>          moab::EigenDecomp<moab::__**Matrix3,
>> moab::CartVect>(moab::Matrix3
>>      >>>> const&, double*, moab::CartVect*)':
>>     OrientedBox.cpp:(.text.___**ZN4moab11EigenDecompINS___**
>> 7Matrix3ENS_8CartVectEEENS___**9ErrorCodeERKT_PdPT0_[moab::__**ErrorCode
>>      >>>> const&, double*, moab::CartVect*)]+0xb7f):
>>      >>>>          undefined
>>      >>>>          reference to `std::cerr'
>>      >>>> const&, double*, moab::CartVect*)]+0xb84):
>>      >>>>          undefined
>>      >>>>          reference to `std::basic_ostream<char,
>> >&, char
>>      >>>> const*)'
>>      >>>> const&, double*, moab::CartVect*)]+0xb89):
>>      >>>>          undefined
>>      >>>> const&, double*, moab::CartVect*)]+0xb91):
>>      >>>>          undefined
>>      >>>>          std::char_traits<char> >& (*)(std::basic_ostream<char,
>> OrientedBox.o):(.eh_frame+__**0x22f):
>>      >>>>          Thanks,
>>      >>>>          Ami
>>      >>>>          ______________________________**___________________
>>      >>>>          Nek5000-users mailing list
>>      >>>>          Nek5000-users at lists.mcs.anl.__**gov
>>      >>>> <mailto:Nek5000-users at lists.**mcs.anl.gov<Nek5000-users at lists.mcs.anl.gov>
>>      >>>>          https://lists.mcs.anl.gov/__**
>> mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>
>>      >>>>          <https://lists.mcs.anl.gov/**
>> mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> __============================**==__====
>>      >>>>      "You will keep in perfect peace him whose mind is
>>      >>>>         steadfast, because he trusts in you."
>> Isaiah 26:3
>>      >>>>                    Tim Tautges            Argonne National
>> Laboratory
>>      >>>>                (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov
>>      >>>> (telecommuting from UW-Madison)
>>      >>>>        phone (gvoice): (608) 354-1459<tel:%28608%29%20354-1459>      1500
>>      >>>> Engineering Dr.
>>      >>>>                   fax: (608) 263-4499<tel:%28608%29%20263-4499>
>>      >>>> Madison, WI 53706
>>      >>>> <https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>      >>>> Nek5000-users at lists.mcs.anl.**gov<Nek5000-users at lists.mcs.anl.gov>
>>      >>>    steadfast, because he trusts in you."               Isaiah
>> 26:3
>>      >>>               Tim Tautges            Argonne National Laboratory
>>      >>>           (tautges at mcs.anl.gov)      (telecommuting from
>> UW-Madison)
>>      >>>   phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>      >>>              fax: (608) 263-4499      Madison, WI 53706
>>         steadfast, because he trusts in you."               Isaiah 26:3
>>                (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130912/f0c51f54/attachment-0001.html>
