[Nek5000-users] Problem reading binary .fld files into postnek
Mon Sep 9 14:12:52 CDT 2013
Is it the same "error reading REA" problem?  Can you send the terminal
output you are getting and your base .rea file?
You can send if off list, heisey at mcs.anl.gov
Thanks
Katie
On Mon, Sep 9, 2013 at 1:11 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Neks,
> I apologize for the delayed response. Thank you for your suggestions.
> Paul -- my files are in .fld format.
> Kate -- I was using an older version of postnek. I compiled the latest
> version on my computer and tried again, but I'm still running into
> problems.
> Thank you for your time,
> Chris
> On Wed, Sep 4, 2013 at 2:46 PM, Christopher Mehrvarzi <chrisom3 at vt.edu>wrote:
>> Hi Paul,
>> Thank you for your suggestions. I am using a standard .rea file and
>> already had the flags at p66 and p67 set to 4 (the extension of my data
>> is .fld) but the problem still occurs. I tried setting the flags to 6
>> anyways but still encountered the same problem.
>> Chris
>> On Wed, Sep 4, 2013 at 9:33 AM, Christopher Mehrvarzi <chrisom3 at vt.edu>wrote:
>>> Hi Neks,
>>> I am having some issues importing my binary-type data into postnek. When
>>> the files are imported into postnek, many of the elements are missing and
>>> this is part of the message that appears in the terminal:
>>> -Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1
>>>  NEKTON Version   2.6
>>>  I/O Error: No String Terminator sent to PRS
>>> Enter Session Name (Default= g40cond_as
>>>  Beginning Session g40cond_as
>>>  renaming SESSION.NAME SESSION.NAME~
>>>  Session name:"g40cond_as
>>> cp: /Users/chris/.nekdefaults: No such file or directory
>>>  renaming g40cond_as.plt01                         g40cond_as.plt01~
>>>  LTRUNC: string:          80
>>>  LTRUNC: string:          28
>>> Wed Sep  4 09:30:51 EDT 2013
>>>  Reading geometry from
>>> XYZ Min,Max:
>>>   -40.0000       40.0000
>>>   -40.0000       40.0000
>>>    0.00000       1.00000
>>>            1        3017           1  TRYING TO READ BC
>>>            7        3072           2  TRYING TO READ BC
>>>            7        3072           3  TRYING TO READ BC
>>>            7        3072           4  TRYING TO READ BC
>>>            7        3072           5  TRYING TO READ BC
>>> Error reading options in .REA file
>>>  this is iffmat: F   4.0000000
>>> g40cond_as
>>> g40cond_as.fld01
>>> The same data can be read correctly in Visit, however. Any ideas?
>>> Additionally, if this problem cannot be overcome, is there a way to take
>>> profile points using Visit or Matlab?
>>> Thank you for your help,
>>> Chris
>>> Christopher O. Mehrvarzi
>>> Paul Research Group
>>> Virginia Tech - Mechanical Engineering
>>> chrisom3 at vt.edu
>> Paul Research Group
>> chrisom3 at vt.edu
> Paul Research Group
> chrisom3 at vt.edu
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130909/5bb82c97/attachment.html>
