[Nek5000-users] MPI-IO in Nek
Sat Oct 19 11:17:59 CDT 2013
Hi Neks
After reading the following post, the inherent differences b/w .fld and
.f000 files became somehow clear to me. However, I have a few questions:
https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2013-June/002147.html
1)      Is this correct that compiling with MPI-IO only requires adding this
flag in makenek:  PPLIST="MPIIO" ? or is there anything else I need to do?
2)      I noticed that if you do not add the above flag but set param(66)
and param(67) in usrdat2 to 6 or -6 ,  it does generate .f000 files. I
assume it implicitly used MPIIO, right?
3)      If I use several directories for outputting multiple files (by say
setting p65=-64 in the .rea file), how can I restart from those multiple
files associated with a single checkpoint in the *.rea* file?
Thanks a lot for your help
Best,
Hesam
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131019/17d1583c/attachment.html>
