[Nek5000-users] turbJet compiling problem
Thu Oct 17 11:10:54 CDT 2013
Hi neks,
I am trying to compile the out-of-the-box turbojet case in the examples.
This is the output I got for PGI:
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_myprocnum':
initpar.c:(.text+0x6): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_ncpus':
initpar.c:(.text+0x16): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_tcpus' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_getioproc':
initpar.c:(.text+0x26): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_ioproc' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_is_ioproc':
initpar.c:(.text+0x36): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
initpar.c:(.text+0x3e): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_ioproc' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_abort':
initpar.c:(.text+0x7a): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_abortp':
initpar.c:(.text+0xe0): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `__hpf_passargs':
initpar.c:(.text+0x4c2): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
initpar.c:(.text+0x616): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
/opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o): In function `pghpf_init':
initpar.c:(.text+0x7d8): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_np2' defined in COMMON section in /opt/pgi/12.8.0/linux86-64/12.8/lib/libpgf90.a(initpar.o)
initpar.c:(.text+0x7e2): additional relocation overflows omitted from the output
make: *** [nek5000] Error 2
and this is for gfortran
obj/postpro.o: In function `intpts_':
postpro.f:(.text+0x1818): relocation truncated to fit: R_X86_64_32S against symbol `intp_r_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1831): relocation truncated to fit: R_X86_64_32S against symbol `intp_r_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1878): relocation truncated to fit: R_X86_64_32S against symbol `intp_i_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1915): relocation truncated to fit: R_X86_64_32S against symbol `intp_r_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1927): relocation truncated to fit: R_X86_64_32S against symbol `intp_i_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1c7d): relocation truncated to fit: R_X86_64_32S against symbol `intp_r_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1dc4): relocation truncated to fit: R_X86_64_32S against symbol `intp_r_' defined in COMMON section in obj/postpro.o
obj/postpro.o: In function `tens3d1_':
postpro.f:(.text+0x1ef0): relocation truncated to fit: R_X86_64_32S against symbol `ctensor_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x1ef8): relocation truncated to fit: R_X86_64_32S against symbol `ctensor_' defined in COMMON section in obj/postpro.o
obj/postpro.o: In function `build_1d_filt_':
postpro.f:(.text+0x2124): relocation truncated to fit: R_X86_64_32S against symbol `cfiltr_' defined in COMMON section in obj/postpro.o
postpro.f:(.text+0x2136): additional relocation overflows omitted from the output
collect2: ld returned 1 exit status
make: *** [nek5000] Error 1
Any help?. Thanks
CSI has been ranked one of America’s Best Colleges 2014<http://colleges.usnews.rankingsandreviews.com/best-colleges/rankings/regional-universities-north/top-public/spp+50/page+2> (North East Public) by US News and World Report.
