[Nek5000-users] Variable density flows
Sun Oct 13 09:08:18 CDT 2013
With such a small diffusion coefficient you typically
are going to need very fine resolution in space.
Maintaining monotonicity (i.e., no over- / undershoots) in
an under-resolved scenario is a current research topic.
For the time being, I typically simply clip when monotonicity
is critical.
Paul
On Sun, 13 Oct 2013, nek5000-users at lists.mcs.anl.gov wrote:
> I am not sure that what you are solving for  c  is a normalized scalar like a mass fraction Y for example
> If c is not normalized May be the formulation is equivalent to
> C= rho* Y where y is a normalized scalar and rho is the total density..
> Finally check mass conservation
> By integrating over the volume of the channel, the density equation
> d/dt integral(rho) + integral (u. Grad rho) =error
> And see how error changes over time
> Ammar
> Sent from my iPhone
>> On Oct 13, 2013, at 1:46 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> On Sun, Oct 13, 2013 at 10:35 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> You can also try error function like profile with 0 value at the inlet and increases to a peak somewhere and stays constant up to the exit so gradient is0 at the exit
>>> Insulation normally refers to the diffusive flux (first form)
>>> Ammar
>> Thanks for the tips. I am using a smoothed initial condition for scalar now. However after some time the scalar does not stay within [0,1] which is important. My time step is already small with cfl ~= 0.1. What can I do to get better behaviour of the scalar ?
>> The diffusion coefficient for my scalar is quite small, D = 5*10^(-5).
>> Regards
>> praveen
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
