[Nek5000-users] Variable density flows
Sat Oct 12 11:34:55 CDT 2013
Hi Praveen,
That looks right... As always, it's best to run a test
to verify first.
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Saturday, October 12, 2013 11:17:06 AM
Subject: Re: [Nek5000-users] Variable density flows
Thanks to Paul and Ammar. I will try the variable density approach.
I am first trying a case in which viscosity depends on temperature and a passive scalar. My uservp looks like this. Can I use "temp" and "PS" to get temperature and passive scalar as below ?
subroutine uservp (ix,iy,iz,ieg)
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
common /mygeom/ xmin,xmax
common /myparam/ r_k,Rey_no,Pr_no,Sc_no,visc_rat
if(ifield.eq.1)then ! momentum equation
utrans= 1.0
udiff = exp(PS(1)*log(visc_rat) - temp)/Rey_no
else if(ifield.eq.2)then ! temperature eqn
utrans= 1.0
udiff = PS(1)*(r_k - 1.0) + 1.0
udiff = udiff/(Rey_no*Pr_no)
else if(ifield.eq.3)then ! passive scalar
utrans= 1.0
udiff = 1.0/(Rey_no*Sc_no)
else
print*,'Only 3 fields'
call exitt()
endif
return
end
Thanks
praveen
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
