[Nek5000-users] Fwd: Variable density flows
Fri Oct 11 13:27:24 CDT 2013
Hi Praveen,
If you want to follow the model of the Guermond paper that you
pointed out then I shouldn't think low Mach is necessary given
that, in their model, div U = 0.
I've not looked into this in detail, however, so I suggest
undertaking a bit of exploration and test.
To specify variable density in Nek, you set ifuservp=.true.
and ifstrs=.true. in usrdat, and then in uservp() you set:
      if (ifield.eq.1) then
         utrans = mydensity
         udiff  = my viscosity
      endif
You also need to set lx2=lx1-2, (same for ly2 and lz2 (if3d));
and set lx1m=lx1,ly1m=ly1,lz1m=lz1 in the SIZE file.
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, October 11, 2013 11:54:38 AM
Subject: Re: [Nek5000-users] Fwd: Variable density flows
Hi Paul
For variable density case do I need to use the low mach number version or some other way ?
Thanks
praveen
On Fri, Oct 11, 2013 at 8:24 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
In principle, this should work with the Pn-Pn-2 STRESS formulation, but
I don't think it has been thoroughly tested.
Regarding large viscosity variations, work needs to be done on the
preconditioners for the viscous terms. This hasn't been a traditional
focus for Nek5000, which has been aimed at high Reynolds number flows
where the viscous solves are essentially trivial (compared to the
pressure, say).
Certainly, there are things that could be done to be effective in
this space. I would start by running some test problems with the
STRESS formulation to see if you get the accuracy you're after. If
so, then we can look into performance enhancement via better preconditioning
strategies for the case at hand.
HTH,
Paul
To: "nek5000" < nek5000-users at lists.mcs.anl.gov >
Sent: Friday, October 11, 2013 9:16:24 AM
Subject: [Nek5000-users] Fwd: Variable density flows
Hello
Can we solve variable density incompressible flows with nek5000 ? For e.g. see the model given by eq. 2.1 here
http://www.math.tamu.edu/~guermond/PUBLICATIONS/guermond_quartapelle_JCP_2000.pdf
Also, can nek handle variable viscosity with large variations ?
Thanks
praveen
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
