[Nek5000-users] Fwd: Extracting data and interpolating
Fri Nov 22 10:21:55 CST 2013
Hi Ami,
One way to do this is to use the hpts() utility.
Try  google nek5000 hpts
and you should see the instructions.
If you don't want the data at every timestep you can just add something
like:
      if (mod(istep,100).eq.0) call hpts()
Best, Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, November 22, 2013 9:48:17 AM
Subject: [Nek5000-users] Fwd: Extracting data and interpolating
Hi Neks,
I am currently working on simulation of 3D curved pipe with Nek5000. I would like to export some data in mid-slice surface and specified line along the curvature of pipe. I am using USERCHK, I can export the variables, but how I can interpolate/write data which desired along the lines and sliced surfaces? and If I do this, interpolation can keep the accuracy of the simulation or not?
Ami
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
