[Nek5000-users] help: 3d revolved mesh
Tue Nov 19 11:04:25 CST 2013
Looking at the error message, it seems there is something wrong with the
source file, coaxJets.rea.  n2to3 is having trouble reading the curve data,
so I would suggest looking there to see that everything looks as expected.
After the mesh data, coaxJets.rea should have something like:
  ***** CURVED SIDE DATA *****
           0 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
  ***** BOUNDARY CONDITIONS *****
It is important for the number of curved sides to match the number of lines
following it.  In this example it is 0, so there are no lines following.
If this doesn't solve your problem, please send me the coaxJets.rea file
off list to: heisey at mcs.anl.gov
and I will take a closer look.
Best,
Katie
On Tue, Nov 19, 2013 at 1:44 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Neks
>    I have created (and succesfully used) a
> 2d axisymmetric mesh (see attachment) for
> two coaxial jets discharging into "free air".
> What I want to do now is to revolve it
> around the z (x) axis to create a 3d one
> and simulate the non-axisymmetric flow .
> I tried using n2to3 without success with the
> following input parameters:
> coaxJets               old name
> coaxJets3              new name
> 1                      For ASCII output only: 0; For .rea/.re2: 1
> -10                    input number of levels: (1, 2, 3,...; < 0 for
> circular sweep.):
> 0                      input z min:
> 360                    input z max:
> 1                      input gain (0=custom,1=uniform,other=geometric
> spacing):
> no                     This is for CEM: yes or no:
> P                      Enter Z (5) boundary condition (P,v,O):
> but I get the following error:
>  this is cbz: P  P   <---
>   ERROR READING CURVE SIDE DATA
>   ABORTING IN ROUTINE RDCURVE.
> I have also tried reducing the mesh to the first
> block only, i.e., the inner tube, but I get the
> same error.
> What am I mistaking?
> Regards
> Jacopo Canton
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131119/cd5d5cab/attachment.html>
