[Nek5000-users] Average solution along lines
Wed Nov 13 05:40:21 CST 2013
Hi Praveen,
Yes, you are correct in assuming that y_average computes
ua(x) = 1/L int_0^L u(x,y) dy
under the assumptions of: 2D, uniform element length in y,
and tensor-product array of elements (e.g., as generated
by genbox).
I wrote an x_average() routine a few weeks back and have
tested it.  I've just now added this to navier5.f --- hopefully it
will work for you.
Be certain you set lelx, lely, and lelz in SIZE, and likewise
nelx,nely,nelz in (say) usrdat(), where you must also add:
     include 'ZPER'
Of course, nelz=lelz=1 in your case.
I
Paul
----- Original Message -----
To: "nek5000" <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, November 12, 2013 10:17:14 PM
Subject: [Nek5000-users] Average solution along lines
Hello
For a 2d simulation I want to compute averages on y = constant lines
ua(y) = (1/L) int_0^L u(x,y) dx
My mesh is cartesian so this should be easy to do. I have seen the y_average function which seems to do just this but I need a x_average function I guess. I can modify this for x averages but would like to check first that y_average computes averages along lines in 2d case ???
Thanks
praveen
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
