[Nek5000-users] visit visualization question
Wed Nov 6 23:39:02 CST 2013
Hi Praveen,
If it is the issue I think you are referring to, then it has to do with how
OpenGL renders.  It takes a quadrilateral and splits it into two triangles.
 If the lower left and bottom right are cyan, and then lower right and
upper left are blue, then splitting into two triangles so that lower left
and bottom right are connected will make a cyan streak go through the quad
... splitting so that lower right and upper left are connect make a blue
streak go through the quad.
Best,
Hank
On Wed, Nov 6, 2013 at 8:27 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello
> When I use visit for color plots, I can almost see the mesh as in the
> attached example. Is this a problem with visit or is my results not correct
> https://www.dropbox.com/s/6gwnwiiide2yn6y/visit0000.png
> https://www.dropbox.com/s/a49vqx72ft2ajxy/visit0001.png
> Thanks
> praveen
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131106/dae2d670/attachment.html>
