[Nek5000-users] fld output
Mon Nov 4 12:28:29 CST 2013
Hi JP,
The last part of subroutine outfld loops over the elements and outputs the
data to the files.  (around lines 430-455).
Inside this loop, fill_tmp is called.  This is where the data is actually
loaded into an array (tdump).  After the array is loaded with the
appropriate data, it is sent to node 0, which calls out_tmp().
out_tmp() is where the data is actually written out into the fld file.
As Paul mentioned, we might be able to give you a more specific explanation
to achieve your desired results with a better understanding of your
objectives.
Best,
Katie
On Mon, Nov 4, 2013 at 6:32 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi JP,
> Just curious regarding your objective -- are you needing
> to read the files, or trying to write some new data?
> If I understand this I might be able to point you in the
> right direction.
> Best, Paul
> On Mon, 4 Nov 2013, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi Katie,
>> Do you mean the looping and output of data occurs in the last part of the
>> 'outfld' subroutine or in the last part of 'prepost.f'? Because I can't
>> seem to figure out where exactly the format of how the data is written to
>> file is set and where it is actually written to file.
>> Thank you,
>> JP
>>  _______________________________________________
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131104/805c96ec/attachment.html>
