[Nek5000-users] prex question
Sun Nov 3 10:43:33 CST 2013
Hi Tubois,
Someone corrects me if I'm wrong, but regarding the gambit/matlab
converter, as far as I remember, it can only handle a three-dimensional
mesh. For such mesh however, it works pretty nicely. I have been using for
almost two years and had almost no problem except when imposing periodic
boundary conditions (which can be handle anyway combining the matlab tool
with prenek).
2013/11/3 <nek5000-users at lists.mcs.anl.gov>
> Hello everyone,
> 1, I am trying to create the mesh of the example ext_cyl with genbox, and
> pretek. After consulting the email archives online, I almost got it works.
> The question lies on mesh-merging. I used pretex. The commands is listed as
> follows.
> I got a mesh ext_cyl.rea identical to the one in the example, when I
> visualized it with postx. However, when I use xxdiff to examine it, I found
> several differences.
> BOUNDARY CONDITIONS:
> FLUID BOUNDARY CONDITIONS:
>                    11              0.00000    0.00000  .....
> For the file in the example, this line is
> P                 11              1337.00    3.00000  ......
> So which step did I missed? To set the BC in pretek? Can someone gives a
> detailed command lines?
> 2, About creating the mesh, the wiki says that Nek5000 works with Moab
> Cubit, but this software is not free of charge. Is there any other free
> software for meshing? In the archive, I found the discussion about
> converting Gambit (we have Gambit in school) mesh to rea. The guy left an
> email address cmeador at tamu.edu<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users> ,
> which is no more valid.
> Thank you very much!
> Best regards
> Tubois
> Choose a Name for This session:
> ext_cyl
>  Beginning Session ext_cyl
>    1 READ PREVIOUS PARAMETERS
>    2 TYPE IN  NEW  PARAMETERS
>    3 CONJ. HEAT TRANSFER MERGE
> Choose item:
> 1
>            1
>  Enter name of previous session
> box.rea
>    1 BUILD FROM FILE
>    2 BUILD INTERACTIVELY
> Choose item:
> 1
>            1
> (Default= box.rea          )
> I pressed ENTER
>  Will Read Mesh and B.C. data from  box.rea
>      Reading Element      29   [    1C]
>      Reading Element      58   [    1f]
>      Reading Element      87   [    1I]
>      Reading Element     116   [    1l]
>      Reading Element     145   [    1O]
>      Reading Element     174   [    1r]
>      Reading Element     203   [    1U]
>      Reading Element     232   [    1x]
>      Reading Element     261   [    1a]
>      Reading Element     290   [    1D]
>      Reading Element     319   [    1g]
>      Reading Element     348   [    1J]
>      Reading Element     377   [    1m]
>      Reading Element     406   [    1P]
>      Reading Element     435   [    1s]
>      Reading Element     464   [    1V]
>      Reading Element     493   [    1y]
>      Reading Element     522   [    1b]
>      Reading Element     551   [    1E]
>      Reading Element     580   [    1h]
>      Reading Element     609   [    1K]
>      Reading Element     638   [    1n]
>      Reading Element     667   [    1Q]
>      Reading Element     696   [    1t]
>      Reading Element     725   [    1W]
>      Reading Element     754   [    1z]
>      Reading Element     783   [    1c]
>      Reading Element     812   [    1F]
>      Reading Element     841   [    1i]
>      Reading Element     870   [    1L]
>      Reading Element     899   [    1o]
>      Reading Element     928   [    1R]
>      Reading Element     957   [    1u]
>      Reading Element     986   [    1X]
>      Reading Element    1015   [    1A]
>      Reading Element    1044   [    1d]
>      Reading Element    1073   [    1G]
>      Reading Element    1102   [    1j]
>      Reading Element    1131   [    1M]
>      Reading Element    1160   [    1p]
>      Reading Element    1189   [    1S]
>      Reading Element    1218   [    1v]
>      Reading Element    1247   [    1Y]
>      Reading Element    1276   [    1B]
>      Reading Element    1305   [    1e]
>      Reading Element    1334   [    1H]
>      Reading Element    1363   [    1k]
>      Reading Element    1392   [    1N]
>      Reading Element    1421   [    1q]
>      Reading Element    1450   [    1T]
>  drwobjs:            0
> Showing only 90 elements of         1456
>                     *** BUILD MENU ***
>  inside gencen         1456 F           4
>  done gencen         1456
>    1 END    ELEMENTS
>    2 MODIFY ELEMENT
>    3 GLOBAL REFINE
>    4 CURVE SIDES
>    5 DELETE ELEMENT
>    6 ZOOM
>    7 SET GRID
>    8 DEFINE OBJECT
>    9 REDRAW MESH
>   10 IMPORT MESH
>   11 IMPORT VTK MESH
>   12 IMPORT vtx MESH
>   13 REFLECT MESH
> Choose item:
> 10
>           10
> input name of new .rea file
> import.rea
> Would you like to displace existing elements in box?
> y
>  Found          80  curve sides.
>  IFLD:           1           1 T F
>   ***** FLUID   BOUNDARY CONDITIONS *****
>   ***** FLUID   BOUNDARY CONDITIONS *****$
>  This is nel,ncurve old:        1456           0
>  This is nel,ncurve new:        1536          80
>  inside gencen         1536 F           4
>  done gencen         1536
>  X min/max of new elements:  -1.200000       1.200001
>  Y min/max of new elements:  -1.200000       1.200000
>  NO KEEP:         514 F  -1.0500000      -1.0500000       0.0000000
>  NO KEEP:         515 F -0.75000000      -1.0500000       0.0000000
>  NO KEEP:         516 F -0.45000002      -1.0500000       0.0000000
>  NO KEEP:         517 F -0.15000001      -1.0500000       0.0000000
>  NO KEEP:         518 F  0.15000001      -1.0500000       0.0000000
>  NO KEEP:         519 F  0.45000002      -1.0500000       0.0000000
>  NO KEEP:         520 F  0.75000000      -1.0500000       0.0000000
>  NO KEEP:         521 F   1.0500000      -1.0500000       0.0000000
>  NO KEEP:         570 F  -1.0500000     -0.75000000       0.0000000
>  NO KEEP:         571 F -0.75000000     -0.75000000       0.0000000
>  NO KEEP:         572 F -0.45000002     -0.75000000       0.0000000
>  NO KEEP:         573 F -0.15000001     -0.75000000       0.0000000
>  NO KEEP:         574 F  0.15000001     -0.75000000       0.0000000
>  NO KEEP:         575 F  0.45000002     -0.75000000       0.0000000
>  NO KEEP:         576 F  0.75000000     -0.75000000       0.0000000
>  NO KEEP:         577 F   1.0500000     -0.75000000       0.0000000
>  NO KEEP:         626 F  -1.0500000     -0.45000002       0.0000000
>  NO KEEP:         627 F -0.75000000     -0.45000002       0.0000000
>  NO KEEP:         628 F -0.45000002     -0.45000002       0.0000000
>  NO KEEP:         629 F -0.15000001     -0.45000002       0.0000000
>  NO KEEP:         630 F  0.15000001     -0.45000002       0.0000000
>  NO KEEP:         631 F  0.45000002     -0.45000002       0.0000000
>  NO KEEP:         632 F  0.75000000     -0.45000002       0.0000000
>  NO KEEP:         633 F   1.0500000     -0.45000002       0.0000000
>  NO KEEP:         682 F  -1.0500000     -0.15000001       0.0000000
>  NO KEEP:         683 F -0.75000000     -0.15000001       0.0000000
>  NO KEEP:         684 F -0.45000002     -0.15000001       0.0000000
>  NO KEEP:         685 F -0.15000001     -0.15000001       0.0000000
>  NO KEEP:         686 F  0.15000001     -0.15000001       0.0000000
>  NO KEEP:         687 F  0.45000002     -0.15000001       0.0000000
>  NO KEEP:         688 F  0.75000000     -0.15000001       0.0000000
>  NO KEEP:         689 F   1.0500000     -0.15000001       0.0000000
>  NO KEEP:         738 F  -1.0500000      0.15000001       0.0000000
>  NO KEEP:         739 F -0.75000000      0.15000001       0.0000000
>  NO KEEP:         740 F -0.45000002      0.15000001       0.0000000
>  NO KEEP:         741 F -0.15000001      0.15000001       0.0000000
>  NO KEEP:         742 F  0.15000001      0.15000001       0.0000000
>  NO KEEP:         743 F  0.45000002      0.15000001       0.0000000
>  NO KEEP:         744 F  0.75000000      0.15000001       0.0000000
>  NO KEEP:         745 F   1.0500000      0.15000001       0.0000000
>  NO KEEP:         794 F  -1.0500000      0.45000002       0.0000000
>  NO KEEP:         795 F -0.75000000      0.45000002       0.0000000
>  NO KEEP:         796 F -0.45000002      0.45000002       0.0000000
>  NO KEEP:         797 F -0.15000001      0.45000002       0.0000000
>  NO KEEP:         798 F  0.15000001      0.45000002       0.0000000
>  NO KEEP:         799 F  0.45000002      0.45000002       0.0000000
>  NO KEEP:         800 F  0.75000000      0.45000002       0.0000000
>  NO KEEP:         801 F   1.0500000      0.45000002       0.0000000
>  NO KEEP:         850 F  -1.0500000      0.75000000       0.0000000
>  NO KEEP:         851 F -0.75000000      0.75000000       0.0000000
>  NO KEEP:         852 F -0.45000002      0.75000000       0.0000000
>  NO KEEP:         853 F -0.15000001      0.75000000       0.0000000
>  NO KEEP:         854 F  0.15000001      0.75000000       0.0000000
>  NO KEEP:         855 F  0.45000002      0.75000000       0.0000000
>  NO KEEP:         856 F  0.75000000      0.75000000       0.0000000
>  NO KEEP:         857 F   1.0500000      0.75000000       0.0000000
>  NO KEEP:         906 F  -1.0500000       1.0500000       0.0000000
>  NO KEEP:         907 F -0.75000000       1.0500000       0.0000000
>  NO KEEP:         908 F -0.45000002       1.0500000       0.0000000
>  NO KEEP:         909 F -0.15000001       1.0500000       0.0000000
>  NO KEEP:         910 F  0.15000001       1.0500000       0.0000000
>  NO KEEP:         911 F  0.45000002       1.0500000       0.0000000
>  NO KEEP:         912 F  0.75000000       1.0500000       0.0000000
>  NO KEEP:         913 F   1.0500000       1.0500000       0.0000000
>  Deleting element      514 of     1536.
>  Deleting element      515 of     1536.
>  Deleting element      516 of     1536.
>  Deleting element      517 of     1536.
>  Deleting element      518 of     1536.
>  Deleting element      519 of     1536.
>  Deleting element      520 of     1536.
>  Deleting element      521 of     1536.
>  Deleting element      570 of     1536.
>  Deleting element      571 of     1536.
>  Deleting element      572 of     1536.
>  Deleting element      573 of     1536.
>  Deleting element      574 of     1536.
>  Deleting element      575 of     1536.
>  Deleting element      576 of     1536.
>  Deleting element      577 of     1536.
>  Deleting element      626 of     1536.
>  Deleting element      627 of     1536.
>  Deleting element      628 of     1536.
>  Deleting element      629 of     1536.
>  Deleting element      630 of     1536.
>  Deleting element      631 of     1536.
>  Deleting element      632 of     1536.
>  Deleting element      633 of     1536.
>  Deleting element      682 of     1536.
>  Deleting element      683 of     1536.
>  Deleting element      684 of     1536.
>  Deleting element      685 of     1536.
>  Deleting element      686 of     1536.
>  Deleting element      687 of     1536.
>  Deleting element      688 of     1536.
>  Deleting element      689 of     1536.
>  Deleting element      738 of     1536.
>  Deleting element      739 of     1536.
>  Deleting element      740 of     1536.
>  Deleting element      741 of     1536.
>  Deleting element      742 of     1536.
>  Deleting element      743 of     1536.
>  Deleting element      744 of     1536.
>  Deleting element      745 of     1536.
>  Deleting element      794 of     1536.
>  Deleting element      795 of     1536.
>  Deleting element      796 of     1536.
>  Deleting element      797 of     1536.
>  Deleting element      798 of     1536.
>  Deleting element      799 of     1536.
>  Deleting element      800 of     1536.
>  Deleting element      801 of     1536.
>  Deleting element      850 of     1536.
>  Deleting element      851 of     1536.
>  Deleting element      852 of     1536.
>  Deleting element      853 of     1536.
>  Deleting element      854 of     1536.
>  Deleting element      855 of     1536.
>  Deleting element      856 of     1536.
>  Deleting element      857 of     1536.
>  Deleting element      906 of     1536.
>  Deleting element      907 of     1536.
>  Deleting element      908 of     1536.
>  Deleting element      909 of     1536.
>  Deleting element      910 of     1536.
>  Deleting element      911 of     1536.
>  Deleting element      912 of     1536.
>  Deleting element      913 of     1536.
>  drwobjs:            0
> Showing only 90 elements of         1472
>  drwobjs:            0
>  inside gencen         1472 F           4
>  done gencen         1472
>    1 END    ELEMENTS
>    2 MODIFY ELEMENT
>    3 GLOBAL REFINE
>    4 CURVE SIDES
>    5 DELETE ELEMENT
>    6 ZOOM
>    7 SET GRID
>    8 DEFINE OBJECT
>    9 REDRAW MESH
>   10 IMPORT MESH
>   11 IMPORT VTK MESH
>   12 IMPORT vtx MESH
>   13 REFLECT MESH
> Choose item:
> 1
>            1
>    1 ACCEPT MATL,QVOL
>    2 SELECT ELEMENT
>    3 SELECT MATL [  0]
>    4 SET  MATL PROPS,Q
>    5 SHOW MATL PROPS,Q
> Choose it
> 1
>            1
>  start locglob_lexico:           4        1472        5888  1.99999996E-02
>  locglob:           1           1        5888
>  locglob:           2          81        5888
>  locglob:           1        1562        5888
>  locglob:           2        1562        5888
>  Performing unique_vertex2 self_chk        5888
>  done locglob_lexico:      1562      1562      5888         5
>  Performing makecell self_chk        5888
>               *** MIDWAY BREAK MENU ***
> ABORT to write build data to file and exit
> SET B.C'S to continue
>    1 SET BCs
>    2 ABORT
> Choose item:
>            2
>  Generating Mesh Points for      1472  Elements
>         1472  this is nel in prexit
> Writing Parameters to file
> Deleting tmp.* files.
>   Exiting session   4.59163468E-41
> Nek5000-users mailing list
Jean-Christophe Loiseau
Homepage <https://sites.google.com/site/loiseaujc/>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131103/946acf49/attachment-0001.html>
