[Nek5000-users] trouble with visit
Wed Mar 20 08:43:54 CDT 2013
Hi Joerg,
Normally the output is indeed in single precision.
It's not clear to me the double-precision + visit
is working - but I've been a bit out of the loop
on this.
Paul
On Wed, 20 Mar 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I am facing problems with the visualization in visit.
> The output of the three scalar fields uzt, epst, epsv
> is done is seen in the following line from my usr file.
> Here, I wrote the data into four files (see further below).
> I also attach the visit  script
> !-------usr file-------------------------------------------------
>        tiny=1.e-16
>        do i=1,n
>         epst(i)=log(epst(i)+tiny)
>         epsv(i)=log(epsv(i)+tiny)
>        enddo
> !-------No pressure field, no scalar output
>        ifpo=.false.
>        ifto=.false.
>        call outpost2( uzt,epst,epsv,pr,t,0,'eps')
>        ifpo=.true.
>        ifto=.true.
> !-------Visit script------------------------------------------------
> NEK5000
> version: 1.0
> filetemplate: epsG1_64%d.f%05d
> firsttimestep: 1
> numtimesteps: 1
> !-------the four files that have to be load into visit and which make up one snapshot--------------
> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:03 epsG1_640.f00001
> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:09 epsG1_641.f00001
> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:16 epsG1_642.f00001
> -rw-r--r-- 1 josc1234 linux 2657536136 27. Feb 08:22 epsG1_643.f00001
> -rw-r----- 1 josc1234 linux         87 20. Mär 13:37 vis.nek5000
> !-------This is the error message in visit---------------------------------------
> The compute engine running on makalu51.rz.tu-ilmenau.de has exited abnormally.
> Shortly thereafter, the following occured...
> The Pseudocolor plot of "y_velocity" for the file "/usr/wrk/people4/josc1234/nek5_visit/r095_Lx1_12_Ra1e8/vis.nek5000" could not be generated by the compute engine on host "localhost".
> My questions:
> Could it be that the graphics output should be in single precision?
> I saw that the people at KTH did have similar trouble.
> If yes, how can I switch to single precision in the usr file output?
> For smaller grid it worked.
> Thanks in advance, Joerg.
> Nek5000-users mailing list
