[Nek5000-users] Question about "taylor" example
Tue Mar 12 08:36:47 CDT 2013
You are right. It will still give correct solution.
Thanks
praveen
On Tue, Mar 12, 2013 at 5:52 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Good question...
> It seems to be giving spectral accuracy in any case...
> I can't recall the details of whether the a & b
> influence the result or not.   We'll check into it.
> Thank you Praveen.
> Paul
> On Tue, 12 Mar 2013, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>  Hello
>> In the example "taylor", I notice that the radii r0, r1 are set at line
>> no.
>> 191, 192 here
>> http://trac.mcs.anl.gov/**projects/nek5/browser/**
>> examples/taylor/taylor.usr<http://trac.mcs.anl.gov/projects/nek5/browser/examples/taylor/taylor.usr>
>> but then they are modified at line no. 214, 215. I did not understand the
>> reason for this. Changing r0, r1 will change the parameters "a" and "b".
>> Thanks
>> praveen
>>  ______________________________**_________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130312/ef1e2527/attachment.html>
