[Nek5000-users] Prenek and Genbox - Maketools problems
Fri Jun 7 13:55:56 CDT 2013
Hi JP,
If you want to test my idea, you can just install all of the ubuntu
packages beginning with "fonts-". It's been awhile since I used
Ubuntu, so I can't help you with the install syntax, usually apt-get
or dpkg...
If installing all of them fixes it, then we can try and narrow down
which one is necessary. For example, you'll pull in everything, but
Chinese true type fonts won't be what we're looking for....
Does this make sense?
Best,
Justin
On Fri, Jun 7, 2013 at 5:27 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi All,
> Aleks - thank you for the tip for changing Prenek's window size.
> Justin - Re: The text not showing on menu items - I am using Ubuntu. I have
> tried to install many different types of fonts but the text is still not
> showing. Which font packages did you install to solve the issue?
> The ''I/O Error: No String Terminator sent to PRS' still appears too.
> Thanks,
> JP
> Nek5000-users mailing list
