[Nek5000-users] Prenek and Genbox - Maketools problems
Thu Jun 6 09:26:02 CDT 2013
Hi JP,
What OS are you using? I solved the issue with the text on a GNU/Linux system by installing all of the font packages.
Justin
On Thu, 6 Jun 2013 07:01:20 -0500 (CDT)
nek5000-users at lists.mcs.anl.gov wrote:
> Hi JP,
> The window size in Prenek is set in prenek/xdriver.c with windowh &
> windoww.
> Best.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday, June 6, 2013 6:37:38 AM
> Subject: Re: [Nek5000-users] Prenek and Genbox - Maketools problems
> Dear Paul,
> Thanks. By typing in the X-window as you suggested I have managed to
> start using Prenek to create some geometries, mesh, create curved
> sides etc. etc. Basically I'm trying out the various options there
> are and getting used to them.
> One problem is that in the X-window, the text of the menu items does
> not appear. I.e. I only see grey boxes and must click on the correct
> box by clicking on the 3rd box if for example I need the 3rd menu
> item. Also, is it also normal that the X-window does not size well
> into the screen and some of it is outside the screen?
> Note: The error messages ' 'I/O Error: No String Terminator sent to
> PRS' still appear.
> Thank you,
> JP
> Nek5000-users mailing list
