[Nek5000-users] Problem with multiple file inut
Mon Jun 3 08:08:56 CDT 2013
I would like to read in G1_640.f00006 as the next file.
My question is therefore: where is it exactly encoded that nek wants to read .fld?
As I said, for single output files it works without trouble. Here, I have to split into
multiple files since they become big.
Is   "call restart(4)"  correct?
Thanks a lot.
Am 03.06.2013 um 14:41 schrieb nek5000-users at lists.mcs.anl.gov:
> From the lines of your logfile, I see the first filename G1_640.f00005 read correctly
> Reading checkpoint data
>     0       1 OPEN: G1_640.f00005
> while the next filename you are trying to read shows up as
>     0       1 OPEN: .fld
> which means the second file Nek is trying to read is ".fld" for some reason -- I would suggest checking how you set the filename for the second file.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Monday, June 3, 2013 7:23:22 AM
> Subject: Re: [Nek5000-users] Problem with multiple file inut
> I am sorry, I don't understand your reply:
> my rea file tells me that p66 and p67 specify binary or ascii. We use always binary.
> How does the particular name file enter?
> Am 03.06.2013 um 14:17 schrieb nek5000-users at lists.mcs.anl.gov:
>> For the default/.f format you do not need to set p66 & 67 yourself but I would start with a printout of your p66 and p67 together with the filename you want to read.
>> Aleks
>> Sent: Monday, June 3, 2013 7:11:25 AM
>> Aleks, what does this mean in my particular case.
>> Which name should the files have and which value should I prescribe for p66 and p67.
>> Thanks a lot, Joerg.
>> Am 03.06.2013 um 14:05 schrieb nek5000-users at lists.mcs.anl.gov:
>>> If I am not mistaken p66 and p67 are reset to be equal to 6 later in the code for .f/default format.
>>> The printed filename though has the empty base and extension .fld as if p67 is 4...
>>> Aleks
>>> Sent: Monday, June 3, 2013 7:00:15 AM
>>> Hi Aleks,
>>> p66 and p67 is set to 0.000E+00
>>> Thanks
>>> Am 03.06.2013 um 13:52 schrieb nek5000-users at lists.mcs.anl.gov:
>>>> Hi Joerg,
>>>> Most likely -- for some reason, the reading routines get a filename ".fld":
>>>>    0       1 OPEN: .fld
>>>> .fld
>>>> so you might also want to check a value of parameter(67)
>>>> Best.
>>>> Aleks
>>>> Sent: Monday, June 3, 2013 5:46:23 AM
>>>> Subject: [Nek5000-users] Problem with multiple file inut
>>>> Hi Neks,
>>>> we want to run a post processing job analyzing further things of our full production job.
>>>> For output in single file things work well with the following patch of code in the usr file of
>>>> the analysis program:
>>>>   IF (istep.eq.1) THEN
>>>>    do k=1,xx
>>>>     WRITE(fldfle,'("G1_640.f",I5.5)')k
>>>>     initc(1) = trim(fldfle)
>>>>     call restart(1)
>>>>     …… do your analysis……..
>>>>   enddo
>>>>   ENDIF
>>>> It does the analysis for xx snapshots G1_640.f00001 to G1_640.f000xx that we generated
>>>> before.
>>>> Bigger jobs requires multiple file outputs, e.g. here each snapshot goes into 4 separate files
>>>> G1_640.f0000x to G1_643.f0000x
>>>> I thought that the corresponding extension should do it:
>>>>    do k=1,xx
>>>>     k1=4+k
>>>>     WRITE(fldfle,'("G1_64?.f",I5.5)')k1
>>>>     call restart(4)
>>>>    enddo
>>>>   ENDIF
>>>> the patch of log file (see below) indicates that the program reads G1_640.f00005 to G1_643.f00005 correctly and
>>>> gets stuck afterwards when trying to read the four files G1_64*.f00006:
>>>> New CG1-tolerance (RINIT*epsm) =  0.874462285180112059E-17 0.607013350432080170E-25
>>>> 1     1 Helmholtz VELZ    F:   8.7446E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     2 Helmholtz VELZ    F:   4.5200E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     3 Helmholtz VELZ    F:   3.1000E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     4 Helmholtz VELZ    F:   2.4871E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     5 Helmholtz VELZ    F:   2.0362E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     6 Helmholtz VELZ    F:   1.7312E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     7 Helmholtz VELZ    F:   1.4629E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     8 Helmholtz VELZ    F:   1.2836E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1     9 Helmholtz VELZ    F:   1.1274E-05   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    10 Helmholtz VELZ    F:   9.7394E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    11 Helmholtz VELZ    F:   8.3244E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    12 Helmholtz VELZ    F:   6.8927E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    13 Helmholtz VELZ    F:   5.5410E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    14 Helmholtz VELZ    F:   4.4505E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    15 Helmholtz VELZ    F:   3.5729E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    16 Helmholtz VELZ    F:   2.8812E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    17 Helmholtz VELZ    F:   2.3406E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    18 Helmholtz VELZ    F:   1.9136E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    19 Helmholtz VELZ    F:   1.5656E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    20 Helmholtz VELZ    F:   1.2877E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    21 Helmholtz VELZ    F:   1.0656E-06   1.0000E-06   8.3666E-05   2.0000E+02
>>>> 1    22 Helmholtz VELZ    F:   8.8191E-07   1.0000E-06   8.3666E-05   2.0000E+02
>>>>       1    Hmholtz VELZ:     21   8.8191E-07   8.7446E-05   1.0000E-06
>>>>            L1/L2 DIV(V)    :   2.0122E-21   5.8478E-05
>>>>            L1/L2 QTL       :   0.0000E+00   0.0000E+00
>>>>            L1/L2 DIV(V)-QTL:   2.0122E-21   5.8478E-05
>>>>       1   5.0000E-03  2.8596E+00 Fluid done
>>>> filt amp  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0500
>>>> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000  .9500
>>>>    1  5.0000E-03 -1.3839E-88  1.0000E+00 -3.9134E-06  3.9717E-06 uz_t_mx
>>>> byte swap: F 6.543210030 -0.2931277218E+36
>>>> 12288       1 OPEN: G1_643.f00005
>>>> 4096       1 OPEN: G1_641.f00005
>>>> 8192       1 OPEN: G1_642.f00005
>>>>     1  2.2370E+02 done :: Read checkpoint data
>>>>                           avg data-throughput =   -80.6MBps
>>>>                           io-nodes =     4
>>>>    0       1 OPEN: .fld
>>>> .fld
>>>> byte_read() :: fopen failure2!
>>>> Parameter 65 in the rea file is set to 4. Could it be that the initc is not correctly set?
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
