[Nek5000-users] Problem with multiple file inut
Mon Jun 3 07:00:15 CDT 2013
Hi Aleks,
p66 and p67 is set to 0.000E+00
Thanks
Am 03.06.2013 um 13:52 schrieb nek5000-users at lists.mcs.anl.gov:
> Hi Joerg,
> Most likely -- for some reason, the reading routines get a filename ".fld":
>       0       1 OPEN: .fld
> .fld
> so you might also want to check a value of parameter(67)
> Best.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Monday, June 3, 2013 5:46:23 AM
> Subject: [Nek5000-users] Problem with multiple file inut
> Hi Neks,
> we want to run a post processing job analyzing further things of our full production job.
> For output in single file things work well with the following patch of code in the usr file of
> the analysis program:
>      IF (istep.eq.1) THEN
>       do k=1,xx
>        WRITE(fldfle,'("G1_640.f",I5.5)')k
>        initc(1) = trim(fldfle)
>        call restart(1)
>        …… do your analysis……..
>      enddo
>      ENDIF
> It does the analysis for xx snapshots G1_640.f00001 to G1_640.f000xx that we generated
> before.
> Bigger jobs requires multiple file outputs, e.g. here each snapshot goes into 4 separate files
> G1_640.f0000x to G1_643.f0000x
> I thought that the corresponding extension should do it:
>       do k=1,xx
>        k1=4+k
>        WRITE(fldfle,'("G1_64?.f",I5.5)')k1
>        call restart(4)
>       enddo
>      ENDIF
> the patch of log file (see below) indicates that the program reads G1_640.f00005 to G1_643.f00005 correctly and
> gets stuck afterwards when trying to read the four files G1_64*.f00006:
> New CG1-tolerance (RINIT*epsm) =  0.874462285180112059E-17 0.607013350432080170E-25
>  1     1 Helmholtz VELZ    F:   8.7446E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     2 Helmholtz VELZ    F:   4.5200E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     3 Helmholtz VELZ    F:   3.1000E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     4 Helmholtz VELZ    F:   2.4871E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     5 Helmholtz VELZ    F:   2.0362E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     6 Helmholtz VELZ    F:   1.7312E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     7 Helmholtz VELZ    F:   1.4629E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     8 Helmholtz VELZ    F:   1.2836E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1     9 Helmholtz VELZ    F:   1.1274E-05   1.0000E-06   8.3666E-05   2.0000E+02
>  1    10 Helmholtz VELZ    F:   9.7394E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    11 Helmholtz VELZ    F:   8.3244E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    12 Helmholtz VELZ    F:   6.8927E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    13 Helmholtz VELZ    F:   5.5410E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    14 Helmholtz VELZ    F:   4.4505E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    15 Helmholtz VELZ    F:   3.5729E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    16 Helmholtz VELZ    F:   2.8812E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    17 Helmholtz VELZ    F:   2.3406E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    18 Helmholtz VELZ    F:   1.9136E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    19 Helmholtz VELZ    F:   1.5656E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    20 Helmholtz VELZ    F:   1.2877E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    21 Helmholtz VELZ    F:   1.0656E-06   1.0000E-06   8.3666E-05   2.0000E+02
>  1    22 Helmholtz VELZ    F:   8.8191E-07   1.0000E-06   8.3666E-05   2.0000E+02
>          1    Hmholtz VELZ:     21   8.8191E-07   8.7446E-05   1.0000E-06
>               L1/L2 DIV(V)    :   2.0122E-21   5.8478E-05
>               L1/L2 QTL       :   0.0000E+00   0.0000E+00
>               L1/L2 DIV(V)-QTL:   2.0122E-21   5.8478E-05
>          1   5.0000E-03  2.8596E+00 Fluid done
> filt amp  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0000  .0500
> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000  .9500
>       1  5.0000E-03 -1.3839E-88  1.0000E+00 -3.9134E-06  3.9717E-06 uz_t_mx
> Reading checkpoint data
>       0       1 OPEN: G1_640.f00005
> byte swap: F 6.543210030 -0.2931277218E+36
>   12288       1 OPEN: G1_643.f00005
>    4096       1 OPEN: G1_641.f00005
>    8192       1 OPEN: G1_642.f00005
>        1  2.2370E+02 done :: Read checkpoint data
>                              avg data-throughput =   -80.6MBps
>                              io-nodes =     4
>       0       1 OPEN: .fld
> .fld
> byte_read() :: fopen failure2!
> Parameter 65 in the rea file is set to 4. Could it be that the initc is not correctly set?
> Thanks a lot, Joerg.
> Nek5000-users mailing list
