[Nek5000-users] How to identify boundary faces ?
Wed Jan 30 15:40:17 CST 2013
Dear Nek heads,
I am having trouble getting Nek5000 to read my restart file. The file is an
ASCII file that was written from a previous run. I set parameter p67 to -1
to read in an ascii restart file. Here is the error message in the .o file:
 set initial conditions
 Checking restart options:
sqduct.fld06
 nekuic (1) for ifld            1
 Reading checkpoint data
     WARNING:  No data read in for file
sqduct.fld06
     Failed on  element   2,  point    0.
     Last read dump:
   0.000000      0.2641195E-02   0.000000       0.000000       0.000000
     Last read dump:
   0.000000       0.000000     -0.6859594E-02  0.2343750E-01 -0.2600098E-01
     Last read dump:
  0.2600098E-01 -0.1855469E-01
           0 call exitt 1702a           1
Here is the restart call in the .rea file:
  ***** NO THERMAL BOUNDARY CONDITIONS *****
            1 RESTART OPTIONS FOLLOW
 sqduct.fld06
            1 INITIAL CONDITIONS *****
C Default
Here is the first few lines of the restart file sqduct.fld06:
****   8   8   8 8.0000000E+01 1500 X Y Z U P
NELT,NX,NY,N
  0.000      0.000      0.000      0.000      0.000      0.000
Note that the problem is a square duct with 24 x 24 x 32 elements, which
equal 18432 total elements. Since this is a 5 digit number, I suppose that
is why it is not shown in the first line in the field file.  However, I
tried changing the four *'s to 18432, along with a few other variations,
and no luck, same error. Also, the numbers in the dump after the error
message above don't seem to appear in the restart file. Also, I don't have
any trouble withe a restart file that has only 6 x 6 x 8 = 288 elements in
it. Finally, I am using a version of Nek500 that I downloaded about 11
months ago.
Help is appreciated.
Rich Johnson
On Tue, Jan 29, 2013 at 10:27 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> On Wed, Jan 30, 2013 at 10:13 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hello
>> I want to identify boundary faces to set their boundary condition type.
>> Following some of the examples, I created the following function. To find
>> the location of the face, I need to know the coordinates (xf,yf) of the
>> face center using which I can figure out where the face lies. Is this
>> possible to find ?
>> Thanks
>> praveen
> Hello
> By looking at this
> http://nek5000.mcs.anl.gov/index.php/Element_Definition
> I made the following code. This is a 2d problem and in blue part below I
> am getting face midpoint coordinates. I am not sure I have got the
> numbering of the faces correct.
> Thanks
> praveen
> C=======================================================================
>       subroutine usrdat2
>       include 'SIZE'
>       include 'TOTAL'
>       parameter(XTOL=1e-10)
>       character*3 cbv
>       integer e, f
>       real xmin, xmax, ymax, xf(4), yf(4)
>       xmin = -5.0
>       xmax = +10.0
>       ymax =  3.0
> c set boundary conditions
>       do e = 1,nelv
>          xf(3) = 0.5*(xm1(1,  1,  1,e) + xm1(nx1,1,  1,e))
>          xf(2) = 0.5*(xm1(nx1,1,  1,e) + xm1(nx1,ny1,1,e))
>          xf(4) = 0.5*(xm1(1,  ny1,1,e) + xm1(nx1,ny1,1,e))
>          xf(1) = 0.5*(xm1(1,  ny1,1,e) + xm1(1,  1,  1,e))
>          yf(3) = 0.5*(ym1(1,  1,  1,e) + ym1(nx1,1,  1,e))
>          yf(2) = 0.5*(ym1(nx1,1,  1,e) + ym1(nx1,ny1,1,e))
>          yf(4) = 0.5*(ym1(1,  ny1,1,e) + ym1(nx1,ny1,1,e))
>          yf(1) = 0.5*(ym1(1,  ny1,1,e) + ym1(1,  1,  1,e))
>          do f = 1,2*ndim
>             cbv = cbc(f,e,1)
>             if (cbv.ne.'E  ') then       ! This is boundary edge
>                if(abs(xf(f)-xmin).lt.XTOL)then
>                    cbc(f,e,1) = 'v  '   ! inlet
>                else if(abs(xf(f)-xmax).lt.XTOL)then
>                    cbc(f,e,1) = 'O  '   ! outlet
>                else if(abs(yf(f)-ymax).lt.XTOL)then
>                    cbc(f,e,1) = 'SYM'   ! top wall
>                else
>                    cbc(f,e,1) = 'W  '   ! bottom wall
>                endif
>             endif
>          enddo
>       enddo
>       return
>       end
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130130/36ee1b32/attachment.html>
