[Nek5000-users] Hpts and IBM bluegene
Fri Jan 25 12:19:16 CST 2013
Hi Andrea,
What version number of the code are you using?  There were some problems
with earlier versions.  Can you try updating your source code and seeing
that the file postpro.f is up to date with the current repository number?
--Katie
On Thu, Jan 24, 2013 at 6:08 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi neks,
> I had some problems with the routine hpts on a cluster IBM bluegene.
> The simulations hold when the routine is called. I though that it is
> related to same kind of input output buffer problem. Any hints?
> I used the gnu compilers mpicc -gcc and mpif77 -gfortran.
> Best
> Andrea
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130125/b7823f1e/attachment.html>
