[Nek5000-users] Rayleigh Benard with symmetry BCs
Tue Feb 19 09:55:22 CST 2013
David-
I think this may have gotten past this issue.  It now appears that the Helmholtz solver is converging (if I make DT small enough).  However I can't get this to run longer than 30 seconds of wall clock time.  Is there something I'm missing that could be causing this?
                             -Jared
CCS2/CNLS Postdoctoral Research Associate
Los Alamos National Laboratory
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Monday, February 18, 2013 1:02 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Rayleigh Benard with symmetry BCs
Hi Jared,
I think boundary condition designators in the .box file must be 3 characters, so when you change W to SYM, for instance, you would remove the 2 spaces following W.  See if this works:
SYM,SYM,SYM,SYM,
SYM,SYM,t  ,t  ,
-David
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130219/4c64e364/attachment.html>
