[Nek5000-users] turbulent 3d box
Sun Dec 22 14:59:38 CST 2013
Dear Paul,
You're right.I check your calculations and they are correct!!!.
A huge mistake of mine. Sorry for bothering you. In fact what I meant
was the energy in the velocity field which is
sqrt(3)/2=\int (ux^2+uy^2+uz^2)dxdydz
  So now I am going to recheck your code for nu<1/12 and see if indeed I
obtain those periodic solutions. Did you see the papers?
Another question, again with the interpolation: is it spectrally accurate?
How I compute velocity field derivatives? such as vorticity, pressure,
or strain field in a spectral accuracy?
Furthermore: how in general one computes the energy spectrum of the
velocity field, and the energy in a particular wavenumber ? (in the
spectral methods it is quite straightforward).
Many thanks,
Barak
On 12/22/2013 10:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Barak,
> When I compute the L2 norm of the function, given as:
>         v2 = [ sum_i  vx_i b_i vx_i + vy_i b_i vy_i + vz_i b_i vz_i / sum_i b_i ]^(1/2)
> it comes out to ~ 2.23
> Note that there are some places where ux==2, uy==0, uz==1,
> which would give an L2 norm of
>       sqrt (2*2 + 0*0 + 1*1) = sqrt(5) > sqrt(3)
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Sunday, December 22, 2013 11:04 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] turbulent 3d box
> Hi Paul,
> My definition for velocity magnitude is:
> |v|=sqrt(ux^2+uy^2+uz^2)
> so if you see, there are two components in the form:
> cos^2(x)+sin^2(x)
> etc in each direction
> so in fact
> |v|=sqrt(3) for any x,y,z.
> Isn't correct?
> Barak
> On 12/22/2013 05:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Barak,
>> If your initial condition is:
>>         ux=(cos(y)+sin(z))
>>         uy=(cos(z)+sin(x))
>>         uz=(cos(x)+sin(y))
>> and your domain is [0,2pi]^3, how is it possible that your velocity
>> magnitude
>> is less than 2?
>> What is your measure of velocity magnitude?   When I compute the L2
>> norm of this initial condition I'm seeing about 2.3+
>> Paul
>> *From:* nek5000-users-bounces at lists.mcs.anl.gov
>> *Sent:* Sunday, December 22, 2013 7:53 AM
>> *To:* nek5000-users at lists.mcs.anl.gov
>> *Subject:* Re: [Nek5000-users] turbulent 3d box
>> Hi Paul,
>> It seems that something does not work, comparing my simulations using a
>> standard spectral code (pseudo-spectral). For nu=0.1, I used 16 points
>> for each space direction. Now for this case, the nonlinear terms vanish
>> (just cancel each other) and the solution is just the ABC flow if you
>> set it as initial condition. Then since the forcing is f=nu*ABC the
>> dissipation term (Laplacian) dissipation=-nu*ABC and therefore the
>> initial value (ABC) remains as it is. If we decrease the viscosity above
>> the critical value of 1/12 (if I remember correctly) there is a
>> bifurcation (Hopf...) and we obtain a new periodic solution (in time),
>> where the ABC modes are dominating combined with some high wave numbers
>> that are oscillating.
>>   >From my first tests using NEK, I find that the velocity field (for
>> nu>1/12) does not agree with the above characteristics. For example, the
>> max magnitude of the velocity field should be for the ABC flow sqrt(3),
>> whereas here I get a value close to 2.5.
>> Do you have any idea what's wrong?
>> If you wish to read some literature about the ABC flow as a forcing for
>> Navier Stokes or as a prescribed velocity for generation of magnetic
>> field (i.e., kinematic generation of magnetic field MHD):
>> 1. D. Galloway and U. Frisch. A numerical investigation of magnetic
>> field generation in a flow with chaotic streamlines. Geophysical &
>> Astrophysical Fluid Dynamics, 29(1):13–18, 1984.
>> 2. D. Galloway and U. Frisch. Dynamo action in a family of flows with
>> Geophysical & Astrophysical Fluid Dynamics, 36(1):53–83, 1986.
>> 3. Podvigina, Pouquet, On the non-linear stability of the 1:1:1 ABC flow,
>> Phys. D, Vol. 75, 4, 1994.
>> With my best wishes,
>> Barak
>> Quoting nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>:
>>> Hi Barak,
>>> Thanks for the note about the ABC flow -- that's very useful.
>>> What is your target viscosity?
>>> If you want it to be 0.1, then you would set param 2 in the .rea file
>>> to be 0.1.
>>> Setting param 2 = -0.1 would imply that Re=0.1 or equivalently nu=10.
>>> Does this resolve the issue for you?
>>> Once it's working we could add it as a documented example in the example
>>> suite.
>>> Thanks!
>>> Paul
>>> <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
>>> <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
>>> [nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>]
>>> Sent: Saturday, December 21, 2013 5:24 PM
>>> Hi Paul,
>>> Regarding the 3dbox:
>>> The forcing which I propose is known as the ABC flow
>>> (Arnold-Beltrami-Childress) and has steady solutions (in the form of ABC
>>> flow) with Re=1/nu (nu the viscosity) Re=<12 (in periodic box).
>>> The forcing should be in the form:
>>> f=Re*ABC in order to balance the dissipation term.
>>> This settings can serve as a benchmark for pure hydro/mhd problems.
>>> I tried to fix the example which you have sent me, but I don't succeed
>>> retreiving the expected values.
>>> I attach the relevant files( tarball file).
>>> Best regards,
>>> Barak
>>> On 12/18/2013 03:29 AM, nek5000-users at lists.mcs.anl.gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Hi Barak,
>>>> I added a 3d periodic box under "3dbox" in the examples
>>>> directory.
>>>> Paul
>>>> Dear nek's,
>>>> I would like to run the following problem:
>>>> a 3D periodic box, small viscosity and the following forcing:
>>>> fx=cos(y)+sin(z)
>>>> fy=cos(z)+sin(x)
>>>> fz=cos(x)+sin(y)
>>>> Do you have a similar example?
>>>> Many thanks,
>>>> Barak
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> <mailto:Nek5000-users at lists.mcs.anl>.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> <UrlBlockedError.aspx>
