[Nek5000-users] turbulent 3d box
Tue Dec 17 10:00:22 CST 2013
Hi Paul,
It seems that something is really bad!!
I guess it is with userf() (are x,y,z defined? they should be the
coordinates along the Box axes).
Attached please find the relevant files.
Barak
Could you please look at the attached library. I added the image of the
initial stage.
Barak
On 12/16/2013 07:37 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Sorry - by "blank" .usr file, I meant one of the zero.usr files from
> nek5_svn/trunk/nek
> *From:* nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Monday, December 16, 2013 2:31 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] turbulent 3d box
> Hi Paul,
> It seems that many more things are missing. Here is the compilation errors:
> mpicc -c  -O2 -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE
> -DGLOBAL_LONG_LONG  -DPREFIX=jl_
> /home/galanti/COMPUTING/NEK5000/nek5_svn/trunk/nek/jl/xxt.c -o obj/jl_xxt.o
> /home/galanti/COMPUTING/NEK5000/nek5_svn/trunk/nek/jl/fcrs.c -o
> obj/jl_fcrs.o
> mpif77 -c  -O2 -fdefault-real-8 -fdefault-double-8 -x f77-cpp-input
> -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
> -I/home/galanti/COMPUTING/NEK5000/nek5_svn/TEST-examples/turbBox
> -I/home/galanti/COMPUTING/NEK5000/nek5_svn/trunk/nek -I./
> /home/galanti/COMPUTING/NEK5000/nek5_svn/TEST-examples/turbBox/turbBox.f
> -o obj/turbBox.o
> mpif77 -o nek5000  obj/turbBox.o obj/drive.o obj/drive1.o obj/drive2.o
> obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
> obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
> obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o
> obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o
> obj/cvode_driver.o obj/nek_comm.o obj/init_plugin.o obj/setprop.o
> obj/qthermal.o obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o
> obj/dsygv.o obj/nek_in_situ.o obj/mxm_std.o obj/blas.o obj/comm_mpi.o
> obj/singlmesh.o obj/jl_gs.o obj/jl_sort.o obj/jl_sarray_transfer.o
> obj/jl_sarray_sort.o obj/jl_gs_local.o obj/jl_crystal.o obj/jl_comm.o
> obj/jl_tensor.o obj/jl_fail.o obj/jl_fcrystal.o obj/jl_findpts.o
> obj/jl_findpts_local.o obj/jl_obbox.o obj/jl_poly.o obj/jl_lob_bnd.o
> obj/jl_findpts_el_3.o obj/jl_findpts_el_2.o obj/jl_sparse_cholesky.o
> obj/jl_xxt.o obj/jl_fcrs.o
> obj/drive1.o: In function `nek_init_':
> drive1.f:(.text+0x48b): undefined reference to `usrdat_'
> drive1.f:(.text+0x578): undefined reference to `usrdat3_'
> drive1.f:(.text+0x5b5): undefined reference to `userchk_'
> obj/drive1.o: In function `nek_solve_':
> drive1.f:(.text+0xc7e): undefined reference to `userchk_'
> drive1.f:(.text+0xcf7): undefined reference to `userchk_'
> obj/bdry.o: In function `faceiv_':
> bdry.f:(.text+0x2a5f): undefined reference to `userbc_'
> bdry.f:(.text+0x2e74): undefined reference to `userbc_'
> bdry.f:(.text+0x2f53): undefined reference to `userbc_'
> bdry.f:(.text+0x309f): undefined reference to `userbc_'
> bdry.f:(.text+0x31d9): undefined reference to `userbc_'
> obj/bdry.o:bdry.f:(.text+0x3352): more undefined references to `userbc_'
> follow
> obj/conduct.o: In function `nekuq_':
> conduct.f:(.text+0xdcf): undefined reference to `userq_'
> obj/ic.o: In function `nekuic_':
> ic.f:(.text+0x6a6): undefined reference to `useric_'
> ic.f:(.text+0x980): undefined reference to `useric_'
> ic.f:(.text+0xad0): undefined reference to `useric_'
> obj/ssolv.o: In function `gostep_':
> ssolv.f:(.text+0x1954): undefined reference to `userchk_'
> obj/ssolv.o: In function `go1step_':
> ssolv.f:(.text+0x2424): undefined reference to `userchk_'
> obj/subs1.o: In function `nekuvp_':
> subs1.f:(.text+0x90c): undefined reference to `uservp_'
> collect2: error: ld returned 1 exit status
> make: *** [nek5000] Error 1
> Attached the .usr and .box files which I used. What about the turBox.f
> file ?
> All the best,
> Barak
> Quoting nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>:
>> Hi Barak,
>> Just take the box file from turbChannel
>> and set nelx nely nelz to (say) -8 -8 -8
>> with periodic BCs  P  ,P  ,P  ,P  ,P  ,
>> Then, use a blank .usr file and set ffx fry ffz to be the
>> formulas you have below in userf() in the .usr file.
>> Finally, add the following to usrdat2()
>>      a=0
>>      b=2*pi
>>      call rescale_x(xm1,a,b)
>>      call rescale_x(ym1,a,b)
>>      call rescale_x(zm1,a,b)
>> which will put your box on [0,2pi]^3.
>> Paul
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Sunday, December 15, 2013 4:14:22 PM
>> Subject: [Nek5000-users] turbulent 3d box
>> Dear nek's,
>> I would like to run the following problem:
>> a 3D periodic box, small viscosity and the following forcing:
>> fx=cos(y)+sin(z)
>> fy=cos(z)+sin(x)
>> fz=cos(x)+sin(y)
>> Do you have a similar example?
>> Many thanks,
>> Barak
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> <mailto:Nek5000-users at lists.mcs.anl>.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> <UrlBlockedError.aspx>
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131217/65e03d85/attachment-0001.tar>
