[Nek5000-users] problem with interpolation by hpts
Fri Dec 13 13:07:41 CST 2013
I have a problem with hpts() function to interpolating data. I was using
hpts() function without any problem in userchk and by input it was giving
me the interpolation, but after some days I don't what change I did,
whatever I interpolate now it just gives me multiplication of certain
points(like in one case is 107 points and in other it is 90), I think there
is some problems with setting parameters on SIZE, below is my SIZE file for
one of my cases which I can just get interpolation with multiplication of
107 points (if I have less than 107 points in hpts.in, it just gives me
nothing in htps.out!!):
C     Dimension file to be included
C
C     HCUBE array dimensions
C
      parameter (ldim=3)
      parameter (lx1=6,ly1=lx1,lz1=lx1,lelt=410,lelv=lelt)
      parameter (lxd=10,lyd=lxd,lzd=lxd)
      parameter (lelx=1,lely=1,lelz=1)
      parameter (lzl=3 + 2*(ldim-3))
      parameter (lx2=lx1-2)
      parameter (ly2=ly1-2)
      parameter (lz2=lz1-2)
      parameter (lx3=lx1)
      parameter (ly3=ly1)
      parameter (lz3=lz1)
      parameter (lp = 512)
      parameter (lelg = 16000)
c
c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
c
      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
      parameter (lpx2=1,lpy2=1,lpz2=1)
c
c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
c
      parameter (lbelv=1,lbelt=1)                ! MHD
      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
      parameter (lbx2=1,lby2=1,lbz2=1)
C     LX1M=LX1 when there are moving meshes; =1 otherwise
      parameter (lx1m=1,ly1m=1,lz1m=1)
      parameter (ldimt= 2)                       ! 3 passive scalars + T
      parameter (ldimt1=ldimt+1)
      parameter (ldimt3=ldimt+3)
c
c     Note:  In the new code, LELGEC should be about sqrt(LELG)
c
      PARAMETER (LELGEC = 1)
      PARAMETER (LXYZ2  = 1)
      PARAMETER (LXZ21  = 1)
      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
      PARAMETER (LXZ=LX1*LZ1)
      PARAMETER (LORDER=3)
      PARAMETER (MAXOBJ=4,MAXMBR=LELT*6)
      PARAMETER (lhis=200)         ! # of pts a proc reads from hpts.in
                                   ! Note: lhis*np > npoints in hpts.in
C
C     Common Block Dimensions
C
      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
C
C     The parameter LVEC controls whether an additional 42 field arrays
C     are required for Steady State Solutions.  If you are not using
C     Steady State, it is recommended that LVEC=1.
C
      PARAMETER (LVEC=1)
C
C     Uzawa projection array dimensions
C
      parameter (mxprev = 20)
      parameter (lgmres = 30)
C
C     Split projection array dimensions
C
      parameter(lmvec = 1)
      parameter(lsvec = 1)
      parameter(lstore=lmvec*lsvec)
c
c     NONCONFORMING STUFF
c
      parameter (maxmor = lelt)
C
C     Array dimensions
C
      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
     $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
     $,NXD,NYD,NZD
c automatically added by makenek
      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
      parameter(lpart = 1  ) ! max number of particles
      integer ax1,ay1,az1,ax2,ay2,az2
      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) ! running
averages
      parameter (lxs=1,lys=lxs,lzs=(lxs-1)*(ldim-2)+1) !New Pressure
Preconditioner
      parameter (lfdm=0)  ! == 1 for fast diagonalization method
Is anyone has idea what is the problem in this case?!
Ami
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20131213/d461a8e5/attachment.html>
