[Nek5000-users] turbJet problem
Mon Dec 9 17:32:07 CST 2013
Hi Tanmoy,
Thank you for the nice reply.
Hmm, considering restart: is it possible? this could also be an
alternative considering the issue of decreasing time step.
Now how could I post my question in open format?
  Thanks again
Barak
On 12/10/2013 01:23 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Barak,
> Your err-run.log clearly shows CFL number increases considerably. So, it
> is indeed a problem of time-stepping stability. So, as you suggest a
> variable time-stepping might be necessary. you could even write a small
> routine in .usr file to control your timestep DT. If you decrease your
> error of divergence, it has nothing to do with simulation time. You can
> control simulation time with NSTEPS of .rea file. However for explicit
> method the region of stability of higher accuracy methods are smaller.
> So, 3rd order accurate method is a little less stable. You could also
> try changing TORDER = 2 , when your jet develops considerably.
> I heard lagrangian formuation could be used in nek5000, but
> unfortunately I do not know that. It will be nice if you post this
> question of lagrangian part in an open format, so that the best person
> in the knowledge of this may answer you.
> Thanks,
> Tanmoy
> On Mon, Dec 9, 2013 at 3:59 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi Tanmoy,
>     It is the 4th time that the program stops (probably because of two
>     big dt). See the end of the log of the run. The time step is
>     dt=1e-3. The first test it was 0.02. It seems that the time step has
>     to be reduced when the jet develops considerably.
>     Perhaps, the best thing to do is to simulate till the time limit
>     when the time step becomes not enough small, to stop, and then
>     restart with the next time step (decreased) till the next stage and
>     so on.
>     Now I have further questions:
>     1. I noticed that there is a parameter to control the error of
>     divergence. If I choose smaller value, how it ncrease the simulation
>     time?
>     2. I am interested in the Lagrangian properties of the flow, i.e.
>     calculating velocity, vorticity or other velocity derivatives at the
>     Lagrangian orbit. Is it possible and which are the available tools?
>     Barak
>     On 12/09/2013 02:56 AM, nek5000-users at lists.mcs.anl.__gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         Hi Barak,
>         I am not aware of variable time stepping in nek5000. The time
>         stepping
>         used is BDFk/EXTk with CFL constraint for stability. You can change
>         TORDER in .rea file to 2 or 3 to make the time stepping 2nd or third
>         order accurate. There is a characteristic based time-stepping
>         though...
>         IFCHAR in .rea file.
>         However, if for a value ot DT you are getting convergence,
>         essentially
>         you should get the same for smaller value of DT. What is the
>         error you
>         are getting after the program aborts after 1200 iterations? It
>         is still
>         stored in your log file I suppose.
>         Thanks,
>         Tanmoy
>         On Sun, Dec 8, 2013 at 12:26 PM,
>         <nek5000-users at lists.mcs.anl.__gov
>         <mailto:nek5000-users at lists.__mcs.anl.gov
>         <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
>              Hi Tanmoy,
>              I have divided by 4 and again my run stopped at iteration
>         1200. My
>              question is: does nek5000 have variable time-stepping?
>              Thanks,
>              Barak
>              On 12/07/2013 08:37 PM, nek5000-users at lists.mcs.anl.____gov
>                  Hi Barak,
>                  it is because of the fact that the generated file format is
>                  probably not
>                  readable in visit. In the *usrchk* subroutine in your
>         .usr file
>                  write
>                  these 2 lines
>                  param(66) = 4
>                  param(67) = 4
>                  before the end of the routine
>                  Then compile and execute your program. Now you will get
>         output
>                  files in
>                  the form of turbJet.fld001, turbJet.fld002, ...and so on.
>                  type in visnek turbJet in your terminal, and generate
>                  *turbJet.nek5000*.
>                  This .nek5000 file can be read by visit.
>                  Thanks,
>                  Tanmoy
>                  On Sat, Dec 7, 2013 at 10:33 AM,
>                  <nek5000-users at lists.mcs.anl.____gov
>         <mailto:nek5000-users at lists.>____mcs.anl.gov <http://mcs.anl.gov>
>         <mailto:nek5000-users at lists.mcs.anl.gov>>>> wrote:
>                       Hi Tanmoy,
>                       Many thanks. It seems that after dividing by 4
>         (dt=0.005)
>                  it runs
>                       and I get output files in the form jet0.fxxxxx .
>                       Now I am trying to visualize them using the
>         precompiled
>                  ubuntu11
>                       version of visit. Unfortunately, I get the
>         following error:
>                         VisIt could not read from the file
>         "/home/galanti/COMPUTATION/______NEK5000/nek5_svn/TEST-______examples/turbJet/jet0.f*
>                       database".
>                       The generated error message was:
>                       There was an error opening
>                       database. It may be an invalid file.  VisIt tried
>         using the
>                       following file format readers to open the file:
>         Nek5000
>                       The following error(s) may be helpful in
>         identifying the
>                  problem:
>                       When attempting to use "Nek", the file matched the
>         general
>                  format
>                       expected by the reader but eventually encountered this
>                  error: "A tag
>                       called filetemplate: must be specified".
>                       What's wrong?
>                       Many thanks again,
>                       Barak
>                       On 12/07/2013 12:42 AM,
>         nek5000-users at lists.mcs.anl.______gov
>                           Hi Barak,
>                           It is a problem with numerical Stability.
>         Decrease DT
>                    in your
>                           .rea file
>                           until the simulations become stable. You could
>         start
>                  with 1/2 DT to
>                           check if simulation is stable, other wise go
>         for 1/4
>                  DT, and
>                           check with
>                           this simple test.
>                           Thanks,
>                           Tanmoy
>                           On Fri, Dec 6, 2013 at 3:31 PM,
>                           <nek5000-users at lists.mcs.anl.______gov
>         <mailto:nek5000-users at lists>.
>         <mailto:nek5000-users at lists>.>______mcs.anl.gov
>         <http://mcs.anl.gov> <http://mcs.anl.gov>
>         <mailto:nek5000-users at lists.mcs.anl.gov>>>>> wrote:
>                                Hello,
>                                I am testing the example turbJet, and it
>         seems
>                  that I have some
>                                problem with output. This are the output
>         files:
>                                jet0.f00001
>                                Moreover, the ran stops with emergency
>         exit at
>                  time 5.64
>                           (CFL too
>                                large?):
>                                         282  DNORM, DIVEX
>         6.2789891850172769E-004
>                                8.4967723454134898E-006
>                                         282   5.6400E+00  1.1065E+01
>         Fluid done
>                                    282  5.6400000E+00  1.1955953E-03
>           6.4269380E-04
>                             9.9999991E-01 e2
>                                  t max/min:   0.0000000000000000
>                    0.0000000000000000
>                                  CFL, Ctarg!   22.504301079496056
>                    2.0000000000000000
>                                  call outfld: ifpsco: T
>                                       283  5.6400E+00 Write checkpoint:
>                                        0     283 OPEN: jet0.f00001
>                                       283  5.6400E+00 done :: Write
>         checkpoint
>                                                               file size =
>                    55.    MB
>                                                               avg
>         data-throughput =
>                           572.1MB/s
>                                                               io-nodes =
>              1
>                                            7  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                                   Latest solution and data are dumped for
>                  post-processing.
>                                   *** STOP ***
>                                            3  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            5  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            0  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            6  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            4  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            2  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                  post-processing.
>                                   *** STOP ***
>                                            1  Emergency exit:
>         283    time =
>                                5.6399999999999677
>                                Thank you,
>                                Barak
>         _______________________________________________________
>                                Nek5000-users mailing list
>                                Nek5000-users at lists.mcs.anl.________gov
>                                <mailto:Nek5000-users at lists
>         <mailto:Nek5000-users at lists>.
>         <mailto:Nek5000-users at lists>.>______mcs.anl.gov
>                           <mailto:Nek5000-users at lists.
>         <mailto:Nek5000-users at lists.>____mcs.anl.gov <http://mcs.anl.gov>
>                  <mailto:Nek5000-users at lists.__mcs.anl.gov
>         <mailto:Nek5000-users at lists.mcs.anl.gov>>>>
>         https://lists.mcs.anl.gov/________mailman/listinfo/nek5000-__users
>         <https://lists.mcs.anl.gov/______mailman/listinfo/nek5000-users>
>         <https://lists.mcs.anl.gov/______mailman/listinfo/nek5000-__users <https://lists.mcs.anl.gov/____mailman/listinfo/nek5000-users>>
>         <https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>__>__>
>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>__>__>__>
>                           Nek5000-users at lists.mcs.anl.______gov
>                  Nek5000-users at lists.mcs.anl.____gov
>         Nek5000-users at lists.mcs.anl.__gov
>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
