[Nek5000-users] convert mesh by MOAB
Thu Aug 29 16:31:24 CDT 2013
mbpart also is not working!!
On Thu, Aug 29, 2013 at 4:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Are you working in serial or parallel?  If the latter you'll have to
> partition the mesh, using moab's mbpart tool...
> - tim
> On 08/29/2013 03:07 PM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Sorry, but that doesn't work too, it gives me
>> Failed to load "pipe.e".
>> Error code: MB_INDEX_OUT_OF_RANGE (1)
>> Error message: pipe.e: Trouble reading vertices
>> I tried every exporting format but none of them wasn't work, I just made
>> a pipe with map type meshing and then I used
>> ''compress ids all" then I exported it as output. everything before that
>> seems good but MOAB gives me different errors!!
>> Thanks,
>> Ami
>> On Thu, Aug 29, 2013 at 3:49 PM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov><mailto:
>> nek5000-users at lists.**mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>>>
>> wrote:
>>     Try going through ExodusII (.exo or .g), that might work.  Also,
>> which version of cubit are you using?
>>     - tim
>>     On 08/29/2013 02:38 PM, nek5000-users at lists.mcs.anl.__**gov <mailto:
>> wrote:
>>         Thanks tim for your answer,
>>         I used that command and now I get this error.
>>         Segmentation fault (core dumped)
>>         I don't know whatis the problem with my meshing because I can
>> convert from gmsh files (.msh) to .h5m but for
>>         cubit it
>>         gets stocked!! Do you have any idea what is the problem wiht my
>> meshing stuff with cubit?
>>         Thanks,
>>         Amirreza
>>         On Thu, Aug 29, 2013 at 2:34 PM, <nek5000-users at lists.mcs.anl._**_gov
>> <mailto:nek5000-users at lists.**mcs.anl.gov<nek5000-users at lists.mcs.anl.gov>
>>         <mailto:nek5000-users at lists.__**mcs.anl.gov <http://mcs.anl.gov><mailto:
>> nek5000-users at lists.**mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>>>>
>> wrote:
>>              Before saving to the .cub file, use the Trelis (Cubit)
>> command "compress ids all".
>>              - tim
>>              On 08/29/2013 01:21 PM, nek5000-users at lists.mcs.anl.__**__gov
>>         <mailto:nek5000-users at lists.**mcs.anl.gov<nek5000-users at lists.mcs.anl.gov>>>
>> wrote:
>>                  Hi All,
>>                  I am trying to convert cubit mesh to .h5m using MOAB
>> (mbconvert blah.cub blah.h5m), but I get this error
>>                  Element ids are not contiguous!
>>                  Failed to load "pipe.cub".
>>                  Error message: No sparse tag CATEGORY value for Vertex 1
>>                  I don't know what is the problem, does anybody can help
>> in this problem. FYI, I used Trelis to make a
>>         mesh, is there
>>                  anything wrong with my geometry or mesh?
>>                  Thanks,
>>                  Ami
>>                  ______________________________**_____________________
>>                  Nek5000-users mailing list
>>                  Nek5000-users at lists.mcs.anl.__**__gov <mailto:
>> Nek5000-users at lists.__**mcs.anl.gov <http://mcs.anl.gov>
>>         <mailto:Nek5000-users at lists.**mcs.anl.gov<Nek5000-users at lists.mcs.anl.gov>
>>         https://lists.mcs.anl.gov/____**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/____mailman/listinfo/nek5000-users>
>>         <https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>
>>         <https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> **>__>
>> ____==========================**==__==__====
>>              "You will keep in perfect peace him whose mind is
>>                 steadfast, because he trusts in you."
>> Isaiah 26:3
>>                            Tim Tautges            Argonne National
>> Laboratory
>>                        (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>
>>         <mailto:tautges at mcs.anl.gov>>)      (telecommuting from
>> UW-Madison)
>>                phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>
>> <tel:%28608%29%20354-1459>      1500
>>         Engineering Dr.
>>                           fax: (608) 263-4499 <tel:%28608%29%20263-4499>
>> <tel:%28608%29%20263-4499>      Madison, WI 53706
>> **>__>
>>         Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.*
>> *mcs.anl.gov <Nek5000-users at lists.mcs.anl.gov>>
>>     ==============================**__============================**
>> ==__====
>>        steadfast, because he trusts in you."               Isaiah 26:3
>>                   Tim Tautges            Argonne National Laboratory
>>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)
>>  (telecommuting from UW-Madison)
>>  1500 Engineering Dr.
>>  Madison, WI 53706
>>     Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.**
>>     https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users><
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130829/08883d8b/attachment-0001.html>
