[Nek5000-users] error in compilation due to high tensor product grid
Mon Aug 26 14:58:11 CDT 2013
Hi Hesam,
Thank you very much for your advice...
Tanmoy
On Mon, Aug 26, 2013 at 12:55 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi Tanmoy,
> I believe you should reduce "lelt" is SIZE (implying that you will use
> more number of processors for your case) and recompile it.
> Hesam
> On 13-08-26 03:40 PM, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi nek users,
> When ever I try to compile a case of TurbChannel using very high
> resolution in x,y,z it would give me error as follows.
> turbChannel.f:(.text+0x24): relocation truncated to fit: R_X86_64_PC32
> against symbol `dimn_' defined in COMMON section in obj/turbChannel.o
> turbChannel.f:(.text+0x4a): relocation truncated to fit: R_X86_64_PC32
> turbChannel.f:(.text+0x7c): relocation truncated to fit: R_X86_64_PC32
> against symbol `gfdmic_' defined in COMMON section in obj/turbChannel.o
> turbChannel.f:(.text+0xb0): relocation truncated to fit: R_X86_64_PC32
> turbChannel.f:(.text+0xdf): relocation truncated to fit: R_X86_64_32S
> against symbol `hcglb_' defined in COMMON section in obj/turbChannel.o
> turbChannel.f:(.text+0x163): relocation truncated to fit: R_X86_64_32S
> turbChannel.f:(.text+0x177): relocation truncated to fit: R_X86_64_PC32
> turbChannel.f:(.text+0x18b): relocation truncated to fit: R_X86_64_PC32
> turbChannel.f:(.text+0x19a): relocation truncated to fit: R_X86_64_PC32
> turbChannel.f:(.text+0x233): relocation truncated to fit: R_X86_64_32S
> against symbol `gauss_' defined in COMMON section in obj/turbChannel.o
> obj/turbChannel.o: In function `set_obj_':
> turbChannel.f:(.text+0x390): additional relocation overflows omitted from
> the output
> collect2: ld returned 1 exit status
> make: *** [nek5000] Error
>  Can anybody please help me on that.
>  Thanks,
>  Tanmoy
> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130826/21ba5e80/attachment.html>
