[Nek5000-users] prenek question
Tue Apr 30 11:32:39 CDT 2013
Thanks Adam!  I've updated iolib_no_graph.f
Paul
On Tue, 30 Apr 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hi
> It seems to work now, but I found 2 typos in iolib_no_graph.f causing pretex
> crashes:
> 1) line 153; WRITE(S,'(3G113.9)',ERR=1) changed to WRITE(S,'(3G13.9)',ERR=1)
> 2) line 184; WRITE(SS(NC+1:NC+5), '(I13)',    changed to
> WRITE(SS(NC+1:NC+13),'(I13)',
> Thank you for help.
> Best regards
> Adam
> On 24/04/13 13:05, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Adam,
>> My apologies - I didn't realize that anyone was using sc.
>> (Glad to hear that it _is_ being used!)
>> I think I've now restored the old functionality --- It was
>> hardwired with a particular resolution just until it gets
>> a bit more usage and we understand the typical use cases
>> for the feature.   Since prenek/postnek do not have standard
>> .usr interfaces, it's often easiest just to modify the code
>> for the application at hand, as the number of free parameters
>> is otherwise innumerable.
>> Please let me know if this revision works for you.
>> Best, Paul
>> On Wed, 24 Apr 2013, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Neks.
>>> I have a question about prenek. I use it to insert a cap in the mesh
>>> connecting pipe with the box, but there is an exit (call prexit) in the
>>> new version of subroutine sc_make_sphere_cap. Why is it so? Is the new
>>> version incomplete? Moreover the resolution is changed by increasing the
>>> number of radii to 7, while I'm using 3. Are you going to add additional
>>> switch to choose resolution?
>>> Regards
>>> Adam
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
