[Nek5000-users] prenek question
Wed Apr 24 06:05:14 CDT 2013
Hi Adam,
My apologies - I didn't realize that anyone was using sc.
(Glad to hear that it _is_ being used!)
I think I've now restored the old functionality --- It was
hardwired with a particular resolution just until it gets
a bit more usage and we understand the typical use cases
for the feature.   Since prenek/postnek do not have standard
.usr interfaces, it's often easiest just to modify the code
for the application at hand, as the number of free parameters
is otherwise innumerable.
Please let me know if this revision works for you.
Best, Paul
On Wed, 24 Apr 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks.
> I have a question about prenek. I use it to insert a cap in the mesh
> connecting pipe with the box, but there is an exit (call prexit) in the new
> version of subroutine sc_make_sphere_cap. Why is it so? Is the new version
> incomplete? Moreover the resolution is changed by increasing the number of
> radii to 7, while I'm using 3. Are you going to add additional switch to
> choose resolution?
> Regards
> Adam
> Nek5000-users mailing list
