[Nek5000-users] Boundary condition loop
Mon Apr 22 09:07:52 CDT 2013
Ah, no worries, after the 15th time of making that mistake, I always declare my integers :).
Are you referring to the facexs and the facexv routines?
Josh
On Apr 22, 2013, at 8:39 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Josh,
> Your approach is the only one I know of.
> Note that there are many routines around that will access
> the points that are on a given face pair (f,e), so you might
> want to check the structure of those for your "Do computations"
> block.
> Don't forget "integer e,f"    :)
> Cheers, Paul
> On Mon, 22 Apr 2013, nek5000-users at lists.mcs.anl.gov wrote:
>> Neks,
>> I need to loop over all element faces that are boundary faces (doesn't matter which type of boundary condition).  I know one way to do this would be
>> do e=1,nelv
>> do f=1,2*ndim
>>   if (cbc(f,e,1).ne.'E  '.and.cbc(f,e,1).ne.'P  ') then
>>       ! Do computations
>>   endif
>> enddo
>> enddo
>> Is there a more elegant solution for this, maybe some array that points to element/face combinations that are boundary conditions?
>> Thanks,
>> Josh
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
