[Nek5000-users] Integrate Temperature Over Volume
Mon Apr 15 11:12:05 CDT 2013
Hi Mike,
The standard way to do this in userchk is (say):
       n = nx1*ny1*nz1*nelt
       tbar = glsc2(t,bm1,n)/voltm1
       write(6,1) istep,time,tbar
     1 format(i9,1p2e12.5,' tbar')
Some Background:
Note that tbar is computed as follows:
      t_integral := | 1*t dV
                  =  1^T B t
where the second line is the discrete inner product of
the "1" vector with Temperature (t) using the diagonal
mass matrix B.
In nek, this is expressed as sum_i bm1_i t_i, which
is evaluated using the global-scalar-product, with 2
arguments,  glsc2() function shown above.  glsc2()
incorporates the requisite global communication to
gather contributions from all processors.  (Hence,
it must also be called by all processors; a local
variant is vlsc2().)
Finally, voltm1 is just the volume of the temperature
domain on mesh 1 (i.e., on the velocity/temperature
mesh, no on the pressure mesh).
Note that
     voltm1 = glsum(bm1,n)
Cheers,
Paul
On Mon, 15 Apr 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Neks.
> I would like to integrate the temperature field over the volume of my mesh, and normalize that by the total volume.
> I'm hoping this can be accomplished with a line or two in the .usr file.
> Can you please either point me toward the correct example problem in the repo, or let me know what to enter.
> Thanks!
> --Mike
> Nek5000-users mailing list
