[Nek5000-users] Question - SIZE Parameters And Compilation Errors
Mon Apr 15 10:09:16 CDT 2013
Hi All,
Trying to run some initial test cases of a problems I'm working on:
- Currently on single node (SMP Linux)
- MPI turned off (IFMPI="false")
- DOF at 5 (lx1=6, lxd=9, lelx=8)
If I run with lp=1,lelt=2160, lelg=2160, for a 12x12x15 mesh, it
compiles and runs fine.
If I up it to lp=1,lelt=4500,lelg=4500, for a 15x15x20 mesh, it crashes
the compile with:
obj/drive2.o: In function `plan4_vol_':
drive2.f:(.text+0x82f): relocation truncated to fit: R_X86_64_32S
against symbol `scrvh_' defined in COMMON section in obj/hsmg.o
drive2.f:(.text+0x837): relocation truncated to fit: R_X86_64_32S
obj/drive2.o: In function `plan3_vol_':
drive2.f:(.text+0xac5): relocation truncated to fit: R_X86_64_32S
drive2.f:(.text+0xacd): relocation truncated to fit: R_X86_64_32S
obj/drive2.o: In function `plan2_vol_':
drive2.f:(.text+0xeb8): relocation truncated to fit: R_X86_64_32S
drive2.f:(.text+0xec0): relocation truncated to fit: R_X86_64_32S
obj/drive2.o: In function `dofcnt_':
drive2.f:(.text+0x170f): relocation truncated to fit: R_X86_64_PC32
against symbol `scrns_' defined in COMMON section in obj/convect.o
obj/drive2.o: In function `settime_':
drive2.f:(.text+0x7cc9): relocation truncated to fit: R_X86_64_PC32
against symbol `cprint_' defined in COMMON section in obj/navier1.o
drive2.f:(.text+0x7cef): relocation truncated to fit: R_X86_64_PC32
drive2.f:(.text+0x7d02): relocation truncated to fit: R_X86_64_PC32
obj/plan4.o: In function `crespsp_':
plan4.f:(.text+0xb23): additional relocation overflows omitted from the
output
collect2: ld returned 1 exit status
make: *** [nek5000] Error 1
Just wondering if this is due to a true limit with the platform/word
size, or if I'm screwing something up...
Murph
PS - Is there any other interface to this list other than raw email?
*Murphy Leo O'Dea, PE"Murph"*
PhD Student, Mechanical Engineering
/School Of Engineering And Computer Science/
/Oakland University/
mlodea at oakland.edu <mailto:mlodea at oakland.edu>
http://www.secs.oakland.edu/~mlodea/
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130415/6c639f0e/attachment-0001.html>
