[Nek5000-users] Output of temperature gradient, scalar dissipation rate and convective flux
Fri Sep 28 04:50:22 CDT 2012
Hi Joerg,
You can set ifpo=.false. just before the call to outpost.
You can then turn it back on.
You can also output multiple passive scalars.  For this, however, you
need to call outpost2(), which has a slightly different interface.
Have a look at the source and hopefully it will be clear how to proceed
if you wish to dump additional scalar fields in that way.
For myself, I tend to just use outpost() and then insert whatever I need
in the vx-vy-vz slots, coupled with different prefixes, as in the example
below.
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, September 28, 2012 10:22:27 AM
Subject: [Nek5000-users] Output of temperature gradient,	scalar dissipation rate and convective flux
thanks for the following suggestion concerning our post processing where we need temperature gradients, scalar dissipation rate and convective heat fluxes:
     subroutine userchk
     parameter (lt=lx1*ly1*lz1*lelt)
     common /mygrad/ tx(lt),ty(lt),tz(lt)
     if (mod(istep,iostep).eq.0) then ! , say,
        call gradm1(tx,ty,tz,t)
        call outpost(tx,ty,tz,pr,t,'gdt') ! write to gdtblah.f000...
     endif
     return
     end
It has however one shortcoming, namely the unnecessary additional output of the pressure field which we don't need
for this analysis.
As far as I can see when going down from the routine outpost --> outpost2 --> prepost  this is a fixed
structure and the pressure field cannot be simply substituted by another scalar field (e.g. the scalar dissipation rate)
since it might have a different dimension (e.g. in case of spaces Pn-Pn-2 which we are using).
--- Can this problem be solved without editing the routines prepost?
--- Is prepost_map inside prepost still necessary?
Thanks, Joerg.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
