[Nek5000-users] Visit reader for double precision f files
Fri Sep 14 16:09:10 CDT 2012
Dear Hank,
thanks a lot for your answer. Indeed, now that I checked myself it turns
out that double precision files work perfectly in version 2.4.0 and
onwards of visit, so this was false alarm, sorry! I will inquire why we
thought in the first place that 64 bit would not work.
Thanks again,
Philipp
On Fri, 14 Sep 2012 00:46:11 +0200, <nek5000-users at lists.mcs.anl.gov>
wrote:
> Hi Philip,
> With regards to VisIt, I am happy to investigate.  IIRC, this issue came
> up
> before and we decided that the reader did work.  (But possibly it slipped
> off my queue and it doesn't work!!)
> If you can make a file available to me (hchilds at lbl.gov), I can pursue.
> With respect to the file format issue, someone else more knowledgable
> will
> need to answer.
> Best,
> Hank
> On Thu, Sep 13, 2012 at 3:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Dear all,
>> We were wondering whether it would be possible to include support for 64
>> bit
>> .f files in the Visit reader for Nek5000. So far, only 32 bit files are
>> supported, which we are hardly using any longer except for those files
>> to
>> visualise with Visit; however we have quite a number of f files
>> (snapshots)
>> from various simulations that we use for different purposes such as the
>> computation of spectra, POD modes etc. for which we naturally chose 64
>> bit
>> due to accuracy consideration. To be able to directly visualise such
>> files
>> in Visit without converting them to 32 bit would be very helpful indeed.
>> Another aspect that came up recently was the question on how to
>> indicate in
>> a f file whether or not the pressure is mapped to the Pn mesh if the
>> Pn/Pn-2
>> method is used. Normally, restart files would not perform this mapping,
>> snapshot files however would do. We were wondering whether a simple
>> solution
>> could be to choose different letters in the header (say "P" for
>> pressure on
>> the Pn mesh and "Q" for pressure on the Pn-2 mesh)?
>> We could give a try for both things here if you think it would not be
>> too
>> difficult...
>> Best regards,
>> Philipp
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
