[Nek5000-users] 2D Axisymmetric in semi-circular annulus
Mon Sep 3 09:06:16 CDT 2012
Hi Aleks,
I've tested this update and it appears to have solved that problem. Thanks for looking into this!
Best wishes,
Adrian
> Hi Adrian,
> We have committed fixes that resolves the issues you had earlier (revision 856).
> Let us now if this works for you.
> Best.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, August 28, 2012 2:19:00 AM
> Subject: Re: [Nek5000-users] 2D Axisymmetric in semi-circular annulus
> OK --- that does not appear to be the issue... will dig a bit
> deeper.
> Paul
> On Tue, 28 Aug 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Adrian,
>> My suspicion is that the issue is somehow related to the SYM bc + curve sides
>> + ifaxis.   Generally, SYM on
>> curve sides implies using the stress formulation.
>> At present, I'm not certain of the status of the combination:
>> IFSTRS  T
>> IFAXIS  T
>> We can look into this as well.
>> Sorry that this has been holding you up.
>> Paul
>> On Mon, 27 Aug 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> Dear Nek users,
>>> I have been attempting to set up a 2D axisymmetric problem with an
>>> azimuthal
>>> velocity, in a semi-circular annulus container (the 2D axisymmetric version
>>> of a spherical shell), but have encountered problems with the terms
>>> evolving
>>> the azimuthal velocity blowing up near to the axis, and wondered if anybody
>>> would be able to help with this?
>>> I have looked at the vortex2 example, and have copied the relevant aspects
>>> to
>>> my .usr and .rea files. I have set IFAXIS=T to get the correct viscous
>>> operators for cylindrical geometry where (x,y)->(z,R), as well as IFHEAT=T,
>>> IFAZIV=T, using temperature as the azimuthal velocity.  My test mesh is
>>> created using prenek, and contains 4 elements on a polar grid from r=0.5 to
>>> 1
>>> and theta=0 to 180. Since elements 2 & 4 have one side touching the R=0
>>> (y=0)
>>> axis, I have used "A" boundary conditions, which are applied to side 1 for
>>> each of these elements, as is required. The remaining BCs are 'SYM' and 'I'
>>> for all of the exterior sides. The .rea file containing the mesh with 4
>>> elements is attached to this email. (In the SIZE file I have set
>>> lx1=20,lxd=30,lx2=lx1-2).
>>> For a simple test, if I set the initial conditions to be a uniform rotation
>>> about the z-axis (setting temp = y), within several time-steps the code
>>> blows
>>> up, giving NaN's for each quantity (I have tested various initial
>>> conditions,
>>> which each give the same error). The line of code that appears to cause
>>> problems is the line ~240 of hmholtz.f, TERM1 =
>>> BM1(I,J,1,IEL)*U(I,J,1,IEL)/YM1(I,J,1,IEL)**2,
>>> since, when this term is set to 0, the code does not produce NaN's. (Though
>>> the viscous operator for the azimuthal velocity is then incorrect...)
>>> When IFHEAT=IFAZIV=F,  i.e. when I am not integrating the
>>> temperature/azimuthal velocity, the code runs without problem on the same
>>> mesh.
>>> I am wondering if there is a problem with how I have set up the mesh that
>>> causes this problem? And if so, is there a way to fix this?
>>> Thanks,
>>> Adrian
>>> Modifications to .usr file are:
>>> c-----------------------------------------------------------------------
>>>     subroutine userf  (ix,iy,iz,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,f,eg
>>>     if(y.gt.0) ffy = temp*temp/y
>>>     return
>>>     end
>>>     subroutine userq  (ix,iy,iz,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,f,eg
>>>     if(y.gt.0) then
>>>       visc = param(2)
>>>       qvol = -uy*temp/y
>>>     endif
>>>     return
>>>     end
>>>     subroutine useric (ix,iy,iz,ieg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     temp = y
>>>     return
>>>     end
>>> My .rea file:
>>> ****** PARAMETERS *****
>>>  2.610000      NEKTON VERSION
>>>          2  DIMENSIONAL RUN
>>>        118  PARAMETERS FOLLOW
>>>  1.00000     p001 DENSITY
>>> 0.10000E-06 p002 VISCOS
>>>  0.00000     p003
>>>  1.00000     p004
>>>  0.00000     p005
>>>  0.00000     p006
>>>  1.00000     p007 RHOCP
>>> 0.100000E-06 p008 CONDUCT
>>>  0.00000     p009
>>>  0.00000     p010 FINTIME
>>> 0.100000E+08 p011 NSTEPS
>>> 0.100000E-03 p012 DT
>>>  0.00000     p013 IOCOMM
>>>  0.00000     p014 IOTIME
>>>  1000.00     p015 IOSTEP
>>>  0.00000     p016 PSSOLVER: 0=default
>>>  1.00000     p017
>>> 0.500000E-01 p018 GRID < 0 --> # cells on screen
>>> -1.00000     p019 INTYPE
>>>  5.00000     p020 NORDER
>>> 0.100000E-06 p021 DIVERGENCE
>>> 0.100000E-08 p022 HELMHOLTZ
>>>  0.00000     p023 NPSCAL
>>> 0.100000E-01 p024 TOLREL
>>> 0.100000E-01 p025 TOLABS
>>> 0.450000     p026 COURANT/NTAU
>>>  3.00000     p027 TORDER
>>>  1.00000     p028 TORDER: mesh velocity (0: p28=p27)
>>>  0.00000     p029 = magnetic visc if > 0, = -1/Rm if < 0
>>>  0.00000     p030 > 0 ==> properties set in uservp()
>>>  0.00000     p031 NPERT: #perturbation modes
>>>  0.00000     p032 #BCs in re2 file, if > 0
>>>  0.00000     p033
>>>  0.00000     p034
>>>  0.00000     p035
>>>  0.00000     p036
>>>  0.00000     p037
>>>  0.00000     p038
>>>  0.00000     p039
>>>  0.00000     p040
>>>  0.00000     p041 1-->multiplicative SEMG
>>>  0.00000     p042 0=gmres/1=pcg
>>>  0.00000     p043 0=semg/1=schwarz
>>>  0.00000     p044 0=E-based/1=A-based prec.
>>>  0.00000     p045 Relaxation factor for DTFS
>>>  0.00000     p046 reserved
>>>  0.00000     p047 vnu: mesh matieral prop.
>>>  0.00000     p048
>>>  0.00000     p049
>>>  0.00000     p050
>>>  0.00000     p051
>>>  0.00000     p052 IOHIS
>>>  0.00000     p053
>>>  0.00000     p054 fixed flow rate dir: |p54|=1,2,3=x,y,z
>>>  0.00000     p055 vol.flow rate (p54>0) or Ubar (p54<0)
>>>  0.00000     p056
>>>  0.00000     p057
>>>  0.00000     p058
>>>  0.00000     p059 !=0 --> full Jac. eval. for each el.
>>>  0.00000     p060 !=0 --> init. velocity to small nonzero
>>>  0.00000     p061
>>>  0.00000     p062 >0 --> force byte_swap for output
>>>  0.00000     p063 =8 --> force 8-byte output
>>>  0.00000     p064 =1 --> perturbation restart
>>>  0.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>>>  0.00000     p066 output : <0=ascii, else binary
>>>  0.00000     p067 restart: <0=ascii, else binary
>>>  0.00000     p068 iastep: freq for avg_all (0=iostep)
>>>  0.00000     p069
>>>  0.00000     p070
>>>  0.00000     p071
>>>  0.00000     p072
>>>  0.00000     p073
>>>  0.00000     p074 verbose Helmholtz
>>>  0.00000     p075
>>>  0.00000     p076
>>>  0.00000     p077
>>>  0.00000     p078
>>>  0.00000     p079
>>>  0.00000     p080
>>>  0.00000     p081
>>>  0.00000     p082
>>>  0.00000     p083
>>>  0.00000     p084 !=0 --> sets initial timestep if p12>0
>>>  0.00000     p085 dt ratio if p84 !=0, for timesteps>0
>>>  0.00000     p086 reserved
>>>  0.00000     p087
>>>  0.00000     p088
>>>  0.00000     p089
>>>  0.00000     p090
>>>  0.00000     p091
>>>  0.00000     p092
>>>  20.0000     p093 Number of previous pressure solns saved
>>>  5.00000     p094 start projecting velocity after p94 step
>>>  5.00000     p095 start projecting pressure after p95 step
>>>  0.00000     p096
>>>  0.00000     p097
>>>  0.00000     p098
>>>  3.00000     p099 dealiasing: <0--> off/3--> old/4--> new
>>>  0.00000     p100
>>>  0.00000     p101 Number of additional modes to filter
>>>  1.00000     p102 Dump out divergence at each time step
>>> 0.100000E-01 p103 weight of stabilizing filter (.01)
>>>  0.00000     p104
>>>  0.00000     p105
>>>  0.00000     p106
>>>  0.00000     p107 !=0 --> add to h2 array in hlmhotz eqn
>>>  0.00000     p108
>>>  0.00000     p109
>>>  0.00000     p110
>>>  0.00000     p111
>>>  0.00000     p112
>>>  0.00000     p113
>>>  0.00000     p114
>>>  0.00000     p115
>>>  0.00000     p116 !=0: x elements for fast tensor product
>>>  0.00000     p117 !=0: y elements for fast tensor product
>>>  0.00000     p118 !=0: z elements for fast tensor product
>>>     4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
>>>  0.00000       0.00000       0.00000       0.00000       0.00000
>>>         12   LOGICAL SWITCHES FOLLOW
>>> T     IFFLOW
>>> T     IFHEAT
>>> T     IFTRAN
>>> T T F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
>>> F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
>>> T     IFAXIS
>>> T     IFAZIV
>>> T     IFSTRS
>>> F     IFMGRID
>>> F     IFMODEL
>>> F     IFKEPS
>>> F     IFCHAR
>>>  10.0000       10.0000      -4.00000      -5.50000
>>> XFAC,YFAC,XZERO,YZERO
>>> **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
>>>        4         2         4 NEL,NDIM,NELV
>>>     ELEMENT          1 [    1C]    GROUP     0
>>> -0.4371138E-07 -0.2185569E-07  0.3535533      0.7071066
>>>  1.000000      0.5000000      0.3535533      0.7071066
>>>     ELEMENT          2 [    1D]    GROUP     0
>>> 0.5000000       1.000000      0.7071066      0.3535533
>>>  0.000000       0.000000      0.7071066      0.3535533
>>>     ELEMENT          3 [    1D]    GROUP     0
>>> 0.5962440E-08  0.1192488E-07 -0.7071066     -0.3535533
>>>     ELEMENT          4 [    1 ]    GROUP     0
>>> -1.000000     -0.5000000     -0.3535533     -0.7071066
>>> 0.8742278E-07  0.4371139E-07  0.3535533      0.7071066
>>> ***** CURVED SIDE DATA *****
>>>        8 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
>>> 2  1 -0.500000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 4  1   1.00000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 2  2   1.00000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 4  2 -0.500000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 2  3   1.00000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 4  3 -0.500000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 2  4 -0.500000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> 4  4   1.00000       0.00000       0.00000       0.00000       0.00000
>>> C
>>> ***** BOUNDARY CONDITIONS *****
>>> ***** FLUID   BOUNDARY CONDITIONS *****
>>> E    1  1   3.00000       1.00000       0.00000       0.00000       0.00000
>>> SYM  1  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> E    1  3   2.00000       3.00000       0.00000       0.00000       0.00000
>>> SYM  1  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> A    2  1   0.00000       0.00000       0.00000       0.00000       0.00000
>>> SYM  2  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> E    2  3   1.00000       3.00000       0.00000       0.00000       0.00000
>>> SYM  2  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> E    3  1   1.00000       1.00000       0.00000       0.00000       0.00000
>>> SYM  3  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> E    3  3   4.00000       3.00000       0.00000       0.00000       0.00000
>>> SYM  3  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> A    4  1   0.00000       0.00000       0.00000       0.00000       0.00000
>>> SYM  4  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> E    4  3   3.00000       3.00000       0.00000       0.00000       0.00000
>>> SYM  4  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> ***** THERMAL BOUNDARY CONDITIONS *****
>>> I    1  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    1  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    2  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    2  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    3  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    3  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    4  2   0.00000       0.00000       0.00000       0.00000       0.00000
>>> I    4  4   0.00000       0.00000       0.00000       0.00000       0.00000
>>>          0  PRESOLVE/RESTART OPTIONS  *****
>>>          7          INITIAL CONDITIONS *****
>>> C Default
>>> C Default
>>> C Default
>>> C Default
>>> C Default
>>> C Default
>>> C Default
>>> ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
>>>          4                  Lines of Drive force data follow
>>> C
>>> C
>>> C
>>> C
>>> ***** Variable Property Data ***** Overrrides Parameter data.
>>>          1  Lines follow.
>>>          0  PACKETS OF DATA FOLLOW
>>> ***** HISTORY AND INTEGRAL DATA *****
>>>          0    POINTS.  Hcode, I,J,H,IEL
>>> ***** OUTPUT FIELD SPECIFICATION *****
>>>          6  SPECIFICATIONS FOLLOW
>>> T       COORDINATES
>>> T       VELOCITY
>>> T       PRESSURE
>>> T       TEMPERATURE
>>> F       TEMPERATURE GRADIENT
>>>          0       PASSIVE SCALARS
>>> ***** OBJECT SPECIFICATION *****
>>>      0 Surface Objects
>>>      0 Volume  Objects
>>>      0 Edge    Objects
>>>      0 Point   Objects
