[Nek5000-users] Setting up a case from scratch
Thu Nov 29 08:00:04 CST 2012
Hi Praveen,
No - they still must be conforming.
If you answer Yes, it will eliminate all elements that have
centers interior to the bounding box of the imported mesh.
The idea of this was that you could build a simple box with
genbox, then have a complex insert that would match 2*d interior
faces within the original box (of dimension d) and have the
insert replace the orginal elements in the interior.
Paul
On Thu, 29 Nov 2012, nek5000-users at lists.mcs.anl.gov wrote:
> This is explained in the primer. Does it mean that the two meshes I want to
> merge need not be conforming, i.e., they can have overlapping parts and
> prenek will fix that.
> Thanks
> praveen
> On Thu, Nov 29, 2012 at 7:15 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Paul
>> Your suggestion works for me. I am asked a question
>> Would you like to displace existing elements in box?
>> What does that mean ?
>> Thanks
>> praveen
