[Nek5000-users] Mesh issue
Mon May 21 07:00:24 CDT 2012
Sorry, I did a mistake the dimensions are 1*0.05*1.
I will try several angles of incline but for now it's 45°.
Hugo
Le 21/05/2012 13:53, nek5000-users at lists.mcs.anl.gov a écrit :
> Hi Hugo,
> Can you tell me again the plate dimension ? (Is it really 1x1x1 ?)
> What is the angle of incline?
> Paul
> On Mon, 21 May 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> Thanks for your quick answer.
>> The boundary conditions of the box are :
>> - W on the 4 sides of the box,
>> - v for the inlet,
>> - O for the outlet,
>> - W for the 6 faces of the plate (placed at the center of the box).
>> I didn't try to do the mesh by tilting the box to do the incline, but
>> I don't really see how to make it.
>> I'm using a MatLab program found on the mailing list of Nek
>> (https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2010-June/000645.html).
>> I noticed that for each blank in the boundary condition the figure in
>> the 4th and the 5th column were 0 (which seems to correspond to a BC
>> like W, v or O).
>>   17650  3 *0* *0.00000* 0.00000 0.00000 0.00000
>> Best regards,
>> Hugo
>> Le 21/05/2012 12:47, nek5000-users at lists.mcs.anl.gov a ?crit :
>>> Hi Hugo,
>>> What are the boundary conditions on your box?
>>> Is there a reason not to simply tilt the box and realize
>>> the incline in this manner?
>>> Boundary conditions invariably have 3 characters in Nek.
>>> I don't know which converter you are using, but "   " as
>>> a bc would translate either to "E  " if it's an interior
>>> element boundary, or to something unknown otherwise.
>>> Best regards,
>>> Paul
>>>> Hi Nek's,
>>>> I'm trying to mesh an inclined flat plate (dimension 1*1*1) in a
>>>> large rectangular box ([-5,5]**3).
>>>> I'm using Gambit to mesh the flat plate and then I'm using a MatLab
>>>> program found on this website to convert the mesh file (from Gambit
>>>> .neu) in the correct format for Nek5000 (.dat).
>>>> The MatLab conversion don't detect errors. But when I'm checking
>>>> the .dat file I see some errors in the fluid boundary condition part :
>>>> E  17650  2  17660 4.00000 0.00000 0.00000 0.00000
>>>>    17650  3  0         0.00000 0.00000 0.00000 0.00000
>>>> E  17650  4  17640 2.00000 0.00000 0.00000 0.00000
>>>> There are some blanks in the first column of this file instead of a
>>>> letter (E,v,O ...) .
>>>> Did somebody already saw this error?
>>>> Is there another way to mesh an inclined flat plate?
>>>> Best Regards,
>>>> Hugo
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120521/db859cb6/attachment.html>
