[Nek5000-users] Mesh issue
Mon May 21 05:47:47 CDT 2012
Hi Hugo,
What are the boundary conditions on your box?
Is there a reason not to simply tilt the box and realize
the incline in this manner?
Boundary conditions invariably have 3 characters in Nek.
I don't know which converter you are using, but "   " as
a bc would translate either to "E  " if it's an interior
element boundary, or to something unknown otherwise.
Best regards,
Paul
On Mon, 21 May 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Nek's,
> I'm trying to mesh an inclined flat plate (dimension 1*1*1) in a large
> rectangular box ([-5,5]**3).
> I'm using Gambit to mesh the flat plate and then I'm using a MatLab program
> found on this website to convert the mesh file (from Gambit .neu) in the
> correct format for Nek5000 (.dat).
> The MatLab conversion don't detect errors. But when I'm checking the .dat
> file I see some errors in the fluid boundary condition part :
> E  17650  2  17660 4.00000 0.00000 0.00000 0.00000
>    17650  3  0         0.00000 0.00000 0.00000 0.00000
> E  17650  4  17640 2.00000 0.00000 0.00000 0.00000
> There are some blanks in the first column of this file instead of a letter
> (E,v,O ...) .
> Did somebody already saw this error?
> Is there another way to mesh an inclined flat plate?
> Best Regards,
> Hugo
